Question about Toshiba Televison & Video
It's a toshiba 32inch tv,9 years old still a great picture but now when u turn it back on the power button flashes red and there's nothing but if u tap the side of the tv it will come on and work perfect what's wrong with my tv thanks.
  • supernascarg Mar 05, 2009
    thanks for your help i dont much about tv's so in my case would be good to take to get fixed,would that be expensive to fix? thanks again.
    is it hard to take out the board i already had the back off.
  • 75 Answers
Sounds like you have bad solder joints on your set coused by heat transfer. You will need to remove the board and look it over real good on the solder side and resolder any that look bad if you can solder or take to shop to have fixed. There is high voltage inside the tv even if it is unpluged from the ac wall outlet. Be sure to unplug before you get inside of the tv even then you can still get zaped and it hurts.
Posted on Mar 05, 2009
  • vic richards Mar 05, 2009
    dont know what it would cost in your area. Just know that I usley charge 40 to50 bucks to do a job like that. If it takes a new part then it is more that I charge. I know that the tv is heavey as all get out. Call a local shop tell them what is going on and what kind of tv it is and that when you slap it or hit it that sometimes it will work ok for a while see what the might charge you that is the best i can tell you.
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
Toshiba 57H81 57" TV Power
I have a toshiba 55hx70 same problem,repair guy just left said it was the power supply and wasnt worth fixing 350 to 400 dollars The tv is 9 years old and they wouldnt even take it to shop. Its been a great tv firs thing to go wrong.. Wo nder if I could replace it myself???
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Nov 03, 2008 | Televison & Video
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Picture wont turn on
Red LED flashes probably five times.
You have not mentioned the model no, so I have to guess it is few years old model.eg FE2 chssis or similar.
Most common reason, R618 270k ohms in power section has gone high.
Second, screen voltage control is slightly misaligned.
Third, high value resistors on tube base, normally two connected to screen voltage control pot have gone high.
You need to have some knowledge , a multi meter and soldering iron and know safety procedures before trying yourself.
Regards
capital98
Nov 30, 2007 | Televison & Video
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv on....tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Erick
Jul 29, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
