The buttons on my keyboard displaying 2 or @ and 3 or # will not respond when I use the shift
  • 1,602 Answers
TRY MAKING A COPY OF THE PROGRAM AND HAVE THE SETUP DONE IN UPPER CASE IF YOU CAN OR WHEN YOU ARE INSTALLING THE PROGRAM INSTALL IN UPPER CASE.
THE KEY IT SELF MAYBE OPEN CIRCIUT ON THOSE 2 KEY SWITCHS, YOU COULD TRY TAKEN THE KB APART AND CLEANING THE CONTACTS, USE A CAN OF COMPRESSED AIR OR AIR COMPRESSOR TO BLOW AIR THREW THE KEYS WHILE YOU DEPRESSING THE KEY AND RELEASING THE KEY.
DELETING THE PROGRAM ALL TOGETHER
RODGANDYSR567
Posted on Mar 05, 2009
Cat sat on keyboard. not a limerick... keyboard slow to respond with arrows and typing. Also light on top LHS under '1'... what is that ?
Hold down the shift button for a few seconds to disable sticky keys. This is a windows feature to help people with disabilities and is activated and disabled by holding the shift button down for a few seconds. You can also disable it under start menu/programs/accessories/accessibility
Jan 22, 2015 | HP Compaq nx9030 Notebook
Why is the @ sign on the letter q
Somebody remapped the keyboard. Are you using Shift 2 for the @ sign?
Apr 06, 2014 | Fujitsu Siemens Fujitsu LifeBook P Series...
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
When I strike the apostrophe, quotation marks (or double appostrophe)appear. When I Shift + apostrophe, double quotations appear. Same thing happens with the tilde key. So far just these 2 keys...
Sounds like a defective keyboard. I seen issues when pressing a button it will trigger another key to be pushed or nothign displays at all. Try replacing keyboard since they are relatively cheap. othersie maybe a software issue
Mar 03, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Acer aspire one net book shift 2 responds as " not @ shift 3 responds as pound sign not #
keyboard was defaulted to US when operating system installed
Go to Contol Pannel-regional settings change keyboard setting to English.........I set then to Australian maybe theres a better setting for others
Mar 19, 2010 | Acer Aspire One PC Notebook
HOW TO USE THE @ BUTTON ONTHE NOTEBOOK
Press the Shift key and the 2 number key
Dec 25, 2009 | Dell Inspiron 6400 Notebook
When i press shift+2 i get " instead of this @
Press the other Shift button, OR press the ALT GR button which is the button on right from the long space bar.
So ALT GR + 2 will give you a unlimited suply of @ @ @ @ @ @@@@@@@@@@@@@@@@@@@@@@@@
Jun 18, 2009 | Dell 0Y3740 Keyboard
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
The buttons on my keyboard with the numbers 2 or @ and 3 or # will not respond when I use the shift to display @ or #
Try to update the keyboard driver. If this does not work you may need to get a new keyboard installed.
Mar 04, 2009 | Acer 2581168-0001 Keyboard
Keyboard
can't bring up the "at" button for to do e-mails. when I shift it it brings up "
Dec 26, 2007 | Compaq 118003-108 Keyboard
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
