Question about Trident (TD9440) (1 MB) Graphic Card
Driver for Tident TD9440 pci video card mb
Driver for trident TD9440 pci video card 1 MB
  • mlrunning Mar 05, 2009
    I just puchased this used card for my older comuptor it has windows xp proffesional on it , i don't have the the driver for the cars
  • Larry Rider
    Larry Rider May 11, 2010
    I would need to know the make and modal number of your computer and your operating system. Larry
  • 38 Answers
Unfortunately this card is very old by todays standards and considered obsolete. You will not be able to find any windows XP drivers for it as it was manufactured way before windows XP was released. There are drivers for windows 95/98 available if you had one of these OS's available. They are available at http://www.video-drivers.com/drivers/76/76393.htm
Hope this helps!
Posted on Mar 05, 2009
Video upgrade
it depends upon your mb. some mb can support pci and agp . some of them support pci and pci-ex . so if your mb has agp or pci-ex slot than you have to buy a video card according to that. video cards range from 128mb to 1024 mb. you have to check your motherboard specification which card it can support. also it depends upon the power supply unit. need at least 300 watts for 128 mb - 256 mb card.
Jan 19, 2010 | Gateway E 1800 (1006023-1) PC Desktop
Where would i find an oil journal on a ford 5.4 trident to install an valve to sample oil
You can tee off on the Oil Pressure sensor, and add a needle valve to get your samples. Your local garage should be able to point it out for you.
Oct 08, 2009 | Trident BLADE T64, (32 MB) PCI Graphic...
3 long beep
The Intel motherboard D845GLVA can only run up to 2GB of 184-pin, 2.5 V, DDR266/200 MHz SDRAM. Test the system by inserting only one stick of memory into slot 1 which is closest to the CPU. Boot system & listen for beep code. If no change remove memory & insert into slot 2 & boot system. Listen for beep code. The Intel D845GLVA MB uses the AMI bios. There is no code to match your 3 long beeps.
Click on the link below, scroll down to AMI;
http://www.computerhope.com/beep.htm
However, you mentioned you loose display when you here the 3 beeps. This is common when a video card is not connected correctly or does not have enough power. Since your MB uses a built-in video card it is very possible that the video controller,
Intel 82845GL Graphics and Memory Controller is going. You can test this theory by buying a PCI video card & installing it into any one of the three PCI slots on the MB. You will not need to enter the MB bios to make any changes. The MB will auto detect the video in the PCI slot & use it over the built -in video. See page 15 in your manual: PCI Auto Configuration.
If you need the manual for your MB you can download it from Intel.
Click on the link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=947&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Any one of the video cards listed on the next link will run in your system;
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards&
Mike
Jun 18, 2009 | Intel Desktop Board D845GLVA...
Dont have VGA software
If you are running Windows XP you can download your driver here: http://www.downloadsource.net/878/Trident-CyberBlade-Video-Driver-Windows-XP/
Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Trident 32 chaintech
http://www.driverskit.com/freedownload/Video_Card/Trident/Blade_3D/11344.html
try the above site
or this site it lists more drivers
http://www.opendrivers.com/categorycompany/12/11638/display-and-video-trident-free-driver-download.html
Aug 05, 2008 | Trident BLADE T64, (32 MB) PCI Graphic...
Trident graphics card
your graphics card need drivers as you computer is only running on basic video what is the card name and number please
Aug 01, 2008 | Trident BLADE T64, (32 MB) PCI Graphic...
Driver
I have a Sapphire X550 512 MB HM Pci-Express Card. But i lost my driver CD. So i want its driver for windows XP-SP2. So how can i find this driver.
Mar 18, 2008 | Sapphire RADEON® X550, (128 MB) PCI...
Trident (TD9440) (1 MB) Graphic Card Logo
944 people viewed this question
Top Trident Computers & Internet Experts
David
David
waruna
NOEL
NOEL
Are you a Trident Computer and Internet Expert? Answer questions, earn points and help others
