Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Hose works but floor unit don't **** any dirt
  • 134 Answers
You have a broken belt. Remove the glide plate and change the belt
Rob
Posted on Mar 05, 2009
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have lots of suction but will not pick up from floor ?
if it will not **** dirt from the floor - then the hose is blocked with dirt and debris. use a wire coat hanger to fish the blockage out of the hose. the blockage usually happens where the hose kinda bends down into the floor unit.
c...
Feb 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
The dirt is staying in the hose when I vacuum, not
that means there is no air flow thru your machine .. thats often caused by clogged (other) filters ..or sometimes a clogged hose .. you can check to make sure you can poke something thru the hose .. a stick or handle, hose or wire (making sure you dont poke thru the side of the hose) .. there are other filters and passageways in the unit that require cleaning or replacement .. if they get clogged then you will have your simptoms .. since there is lilttle air flow then the motor may overheat .. so dont run it long in that condition .. take all the "dirt cup" parts out and wash them all ...
Dec 22, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
May 07, 2009 | Vacuums
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
May 02, 2009 | Dirt Devil Vacuums
Throws dirt back out
High, its blocked up. Check by the brush and all hoses
Mar 11, 2009 | GE 106585 Upright Vacuum
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Vaccuum issue
If the dirt being vacuumed is not going into the dirt cup, then it must be just stuck in the hose and evenually will clog up. Check the hose and see it there is a clog in it, otherwise you have a years warranty on a new vacuum, take it into a warranty shop and have it checked out, take proof of purchase with you.
Oct 31, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
73 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
