I have a Thomas collectors edition antique style am/fm radio that also came with an audio cassette player built into it. It is model BD 121. The unit is about 20 years old. I need to replace the radio band lamp and the cassette drive belt. What voltage and wattage is the lamp supposed to be, and where can I get a new drive belt?
  • 119 Answers
SOURCE: Cassette player belt shredded - need part number???
there are 2 belts the small belt # is 304583201 the longer,wider belt is # 304583102. good luck.
Posted on Nov 15, 2006
  • 83 Answers
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at troublerst@hotmail.com...i hope this helps you
Posted on Jul 12, 2007
  • 22 Answers
SOURCE: Looking for source to replace broken cassette drive belts
find something else with the same size belts there just belts don't have to be same kind i'd go a lil smaller then the old ones
Posted on Mar 27, 2008
Kidyubyub
  • 143 Answers
SOURCE: 1994 Corvette Cassette/Radio?Replace cassette "drive belt"??
Donne Trav, you can take that belt to an electronics shop (your neighborhood shop is best). They will most likely have replacement belts. They will also have a tool that measures the belt so you know which size to get. I used to fix T.V.'s and VCR's. Its the best method when you cannot source an original belt. As far as the diagram, I would need a model # of the radio to even start a search for such a thing.
Posted on May 16, 2008
VOTIT
  • 2071 Answers
SOURCE: RCA audio system,and three disc.
I always encountered that kind of problem,the audio works but discs player not working.This kind of a problem of a disc player had three causes,first the lense is busted already secondly the MPEG MEMORY IC is busted,thirdly the roller that's moving back and port bringing the lense set stock up full of dirt this is most common problem.That why whateveryou did is not functioning.If you know how to open your unit it's better. First you do is to clean the roller with the use of a lighter fluid to take the old greases that already harden with dirt. After that all is clean put a first class greases type-A only little to the roller and wipe the lense with a cotton buds. If all this procedure nothings happens,you better change the lense with desame code number, to avoid conflict.If the lense is change still not functioning that's the time you change the MPEG memory IC.I assure it to you it's works 100%.
Posted on Jun 15, 2008
It works fine. How can I get more sound than the built in speakers can deliver?
You'll need not just speakers but amplifier also. This one you can connect to linear output.
Jul 02, 2015 | Crosley CR42-PA Lancaster Entertainment...
Where is the CD port
Only the RAZ model had both a CD and cassette player built-in. There is a small white 3 letter code on the radio, starting with an "R" - what does your radio say?
Dec 06, 2013 | Chrysler 2001 PT CRUISER Radio a1z111345...
Does the thomas collectors edition jukke box radio modell cr-11 come with a radio tuner if so where is it located
I know you posted this awhile ago, but I just acquired one myself and yes--it does have a tuner. Under the little window with the "record player" in is a panel of songs titles. That flips down and the tuner is underneath. I also have a question--how can I change the burned out lights on one side of mine?
Aug 11, 2011 | Audio Players & Recorders
I bought a '96 Mustang with an Alpine CHM 5620 CD player already installed. The unit appears in great shape and looks as if it were installed by a pro. It seems to load up the CD cartridge and change CDs...
This model of cd changer doesn't have the fm modual built into it. So I am wonder how this setup worked before. Most of these units had an FM tansmitter in them and you would just turn on your factory radio and set the fm tuner to a certain frequency like 89.5 or 91.3, not excatly sure on the right number, but somewhere low in the range. Turn on the stero and try tuning into differnet stations.
But like I said this model is desgined to be used with a aftermarket head unit with the proper wired connection going from the cd changer to the head unit.
Sep 21, 2010 | Alpine Car Audio & Video
I need a power cord for RP-7986 AM/FM Stero Radio/Cassette Recorder/Compact Disc Player.
Depending on where you live, you can find them at Radio Shack, Walmart, most discount electronics parts stores,etc.They are universal except for the physical plug style at the unit side. Best bet is to take the unit with you if possible for a perfect match. Hope this helps
Dec 22, 2009 | RCA RP7986 CD Player
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
399 people viewed this question
 Grubhead
Grubhead
