When printing backlit on the Roland SP 540V I get a ''Temperature is to high'' reading on the display. The printer just stops printing. Print is 50% complete.
  • Anonymous Mar 14, 2014
    roland sp 540v slow
Your room environment must not be over 40degrees Celsius.
Posted on Apr 24, 2009
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Carriage are disconected
How to stop BN20 from beeping due to one empty ink cartridge. Need to purchase replacement.
Aug 05, 2014 | Roland VersaCAMM SP-540V
Roland 540v while printing I get vertical lines of color how do I fix it
The print heads are clogged. Try doing a print head cleaning. If that doesn't work try it again. If it still doesn't work then you need to change the ink cartrage.
Good luck,
Marty
Jun 21, 2014 | Office Equipment & Supplies
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I have roland verscamm sp-540v when i switch on then error comes service call 0101
the 0101 error in sp540 is the Limit Position Initialize has not been done. you find videos on you tube that can help you to do the limit position operation. (you have to enter in Service Mode Menu) its easy to do it yourself. i hope this help.
Dec 24, 2013 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
Roland sp-540v will not print even though the print head moves back and forth as though it is printing. This just started today. Yesterday it worked just fine.
you have a ink problem first check your pump is working read your manual cleaning prints . if heads are blocked get your old ink in waste and pour small amout on the heads to unblock them you might have to do it a few times put back together leave overnight and do a powerful clean and you may have to repeat  afew time read your manual its shows you how to pull apart
Jul 28, 2008 | Office Equipment & Supplies
423 people viewed this question
jasbo
jasbo
