Question about Sony Grand WEGA KF-42SX300 42" LCD TV
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you give me any idea why this has happened? has i have had no problems with the screen untill the new lamp was put in??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Posted on May 18, 2009
  • Dave D Dec 05, 2010
    Check out the class action lawsuits for defective Sony TV. Many models over the past 8 years with the same problem. Do some google search about your model and other similar Sony models with the blue spot and blue smudges on the left side of the screen and at the bottom. Sony is giving free TV's and/or greatly reduced prices for a new model. But hurry as many of the class action lawsuits have already expired.
    http://www.facebook.com/pages/I-Have-a-D...
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a KDF-55XS955 .A yellow splotch just appeared over night on the top right hand side. Starts about 1' top right corner, about 6" wide and the progress down the right side 3-4" from the edge...
This is a common problem for SONY LCD projection TVs. The problem is burned evaporated metal layer on the RGB color lenses. To fix it, you have to purchase a new light engine.
Sep 02, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KF-50WE610 Power Standby light blinking and will turn on seemly randomly for a few seconds with sound and display the shut off and begin blinking again. A purple blob appeared a couple of days ago in...
Sounds like lamp is going out, if when you get lamp replaced, you can do it yourself, the purple blob is still visible, call Sony this may be one of the sets that have an extended warranty on the light engine.
Aug 10, 2009 | Televison & Video
lamp has probably gone out, but, if when you replace lamp purple blob is still on screen then light engine is bad, need to call Sony and see if is on extended warranty.
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Nov 11, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Purple scribbly lines it left hand corner of tv screen
if the lines on your screen looks anything like the image below, you do have a problem with the lcd, problem is you need to replace what is called the light engin. unfortunatly the price of this part is just about as much as a new replacement tv. Get a sceond opinion fron a sony service center near you, as i cannot see your picute. good luck
Dec 22, 2006 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF-42SX300 42" LCD TV Logo
650 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
