Question about Welding Tools
Cutmaster 50 does not shoot air when presss the trigger
If I flip the switch to purge, the air flows freely but when I switch to cut, there is no air. there is not apparent problem with the hose, I have been very caerful not to hurt the hose and I bought the machine new in 03. it has had very limited use and was working fine one minute and the next... nothing. I had never messed with the air pressure controls until just a little earlier that day, I turned the pressure up about 5 pounds because I was cutting some thicker material, (seemed logical) It worked fine but directly after I turned the pressure back down to 70 lbs and tried to make a cut, the machine cut for a split second and then no air... please help...I depend on this machine!
  • 225 Answers
Check the air soleinoid.
Posted on Jul 05, 2009
F2 error code
An F2 error code means usually that you have a flow issue in your hot tub or you have a part malfunction. The best thing to do with an F2 error code is to go through a trouble shooting diagnosis. Start by cutting the power and letting the unit cool down and then do a reset of the equipment. If that does not fix your issue then do a water flow check, clean your filters, release air locks, remove debris from your intakes and returns. If your problem still remains look to replace or repair fuses, heater elements, or your circuit board. I hope this helps.
Nov 09, 2013 | Great Lakes Spas Pool & Spa
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
My 1995 subaru legacy lsi cuts out when I rev the engine around 1 rpm. Plus the check engine light is on. I took it to the dealership and they couldn't fix it, but they got a code from the check engine...
code p 0441 refers to evaporative emission (EVAP) system --incorrect flow detected ==== causes --- hose connection/s--- intake leak---EVAP canister purge valve replace the purge valve
May 21, 2017 | 1995 Subaru Legacy
P1491 - Vacuum Cut Valve Bypass Valve Circuit came
The problem is with the valve or the circuit. First take off the valve connect a 12V source and blow into one of the holes, air should flow freely. With the 12V source removed air should not pass.
With a voltmeter check the valve's connector voltage, it should not be 12V.
The valve generally remains closed, it opens during testing.
Sep 24, 2010 | Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35...
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Not shooting
Trigger Valve needs replacing. Part Number is FA205BA1. The valve comes with instructions, its a pretty easy fix. Any BBostitch dealer should be able to get you one.
Mar 11, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
Car won't start right away after refueling
I just fixed a similar problem on a Toyota Corolla. I'm not certain if your car's EVAP system setup is the same, but this could resolve your problem as well. Your car may have one or both: A refuel check valve, and/or a fuel cutoff valve. Generally these are located off of the fill tube, but the cutoff valve may be mounted on the fuel tank. 01e0b34.jpg
The problem occurs when your fuel tank is overfilled and/or gas flows into the EVAP line. The gas is too high in the filler neck thereby causing fuel to flow into the charcoal canister. A defective refuel and/or fuel cutoff valve would cause this problem. The cutoff valve prevents fuel from flowing into the canister, and the refuel valve helps to trigger the gas pump to stop.
Test refuel check valve (if installed) by blowing air from larger to smaller port. Air should not flow freely and the valve should open as pressure increases. Air should flow freely when blowing from smaller to larger port. Replace valve if it fails either test.
Test the fuel cutoff valve by holding it upright, as installed on car; air should flow freely. Turning upside down should prevent airflow. Also, fuel present in the check valve may indicate the tank was over filled meaning you possibly have fuel in your charcoal canister.
Is your engine warning light on? For the Toyota, code P0441 "Incorrect Purge Flow" was present. Just replacing a defective valve may not get rid of the code. It's possible that your charcoal canister was saturated with gasoline too so that may need to be replaced. I also heard of a situation where the fuel tank was contaminated and had to be cleaned.
Replacing the cutoff valve solved my problem. Good luck! Related Link:
Mar 14, 2009 | 2004 Hyundai Santa Fe
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Welding Tools Logo
176 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
