Question about Maytag Washing Machines
I have 20year old maytag washer,new belt smokes in spin cycle with no clothes in machine
  • moparcharger Mar 06, 2009
    the pump is ok,i think the problem is a brass bearing on the transmision shaft. thanks for the info.
  • moparcharger Mar 08, 2009
    thanks,problem solved
  • Maytag Master
  • 3,361 Answers
Check the water pump. It may be locked up.
Remove the pump belt and turn the pump pulley.
If it will not turn, remove the debris in the pump. No debris, replace the pump.
Posted on Mar 05, 2009
  • steve
    steve Mar 08, 2009
    That is known as the spin bearing and can cause the problem you describe.
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
I have a Maytag Performa PAV 2300 Washing Machine. Recently, clothes are still wet after spinning in the delicate cycle. This is not an issue in the Regular cycle. For now, I'm re-spinning the delicates in...
The belt is real easy to replace. Tip the washer back and yank the old belt off.
Loop the new one over the 2 small pulleys and then ease the belt over the large pulley.themobilian_2154.jpg
Important info a manual and more here
Apr 06, 2011 | Washing Machines
Washer is smoking....
SOUNDS LIKE SHE SPUN THE BELT UNPLUG ELECTRIC , EMPTY WASHER, TIP BACKWARD CHECK UNDERNEATH BELT, IDLER, PULLY AND BRAKE PADS . SEE IF DAMAGED MAY NEW NEW BELT
Feb 04, 2010 | Speed Queen Washing Machines
Spin cycle not working like it should
If the washer doesn't reach it's proper spin speed, the clothes may be wet at the end of the cycle. Since you have replaced the belt, it could be that you have a worn motor pulley or tub bearing. Check for damage to the pulley and shaft and for free play. Also make sure that there are no clothes or foreign objects caught between the inner and outer tubs or something causing friction on the drive train. Hope this helped.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not spin, clutch slipping
Sound like it's time to go shopping, sorry
Jun 20, 2009 | Washing Machines
Neptune mah4000aww spin cycle
BELT IS LOOSING TENSION CAUSING IT TO SMOKE REPLACE BELT
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cloths are still very wet after spin cycle
This sounds like a belt issue. A belt will become weak and stretch or glaze over time. Both of these conditions will cause a slow spin.
The belts are located on the bottom and are relatively easy to replace. Go to: www.repairclinic.com for info on removal and installation. You can even order a new belt from them.
Mar 14, 2009 | Maytag MAV2755A Top Load Washer
Burning smell and smoke
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Feb 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
