Question about Kenmore 24032\24036 Top Load Washer
My agitar struggles under a load. If the washer
My agitar struggles under a load. If the washer is completely full the agitar groans and doesn't move. Under small load everything works fine.
My agitar do not work and it do not spin it look like it was groans before it have alot of black grease looking stuff on the bottom .In Jan I have put a motor coupling on it work good until now.Before the washer was woking good that day
Posted on Apr 07, 2009
  • Kenmore Master
  • 3,361 Answers
Replace the agitator dogs and reduce your load size.
Posted on Mar 05, 2009
My washer will spin but will the clothes will still be dripping clutch on my model and coupling ok.
Tub is not spinning fast enough for the centrifugal force to remove the moisture. check out belts for stretching and slipping.
Dec 07, 2015 | GE Washing Machines
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
¿Qu? tipo de problema tiene con el aparato? Problema m?s com?n con esta m?quina es el kit del cojinete de empuje. ¿No es hacer girar o agitar bien? Si es as?, usted necesita el n?mero de parte 12002513, disponible AQU?. Kelly
Mar 22, 2011 | Maytag PAV2300 Top Load Washer
The agitar isn;t working right. Is there
The part you need is FSP# 80040 dog kit goes inside the upper agitator. installing them dawgs: You sit the agitator on the floor, put you feet on the base and snatch the top portion off of the bottom. You put all the dogs back in the cam set them up into the upper portion with a piece of pvc pipe or equivilent and invert onto the base, lining up the tabs on the bottom with the holes in the upper portion being careful not to smash the tabs on the base that hold the upper portion onto the agitator. Snap it all into place and gently re-install it being careful not to over tighten the nut. Watch this video:
Jun 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer is perfectly level but during the spin
if you can make it rock by hand or by jumping the legs are not adjusted can also rock if the floor is soft... then get thick plywood under the washer ....11/2 inch should be should try to balance the load put heavy things in first
Aug 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer kenmore24032 ser 1001761 m111
sounds like the transmission. take the moter and pump off and manually turn the transmission and see if the tub turns
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Not filling up completely
four inchs under rim is right level any more and it would leak
Nov 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 24032\24036 Top Load Washer Logo
111 people viewed this question
Sal De
 Brian Main
Brian Main
