Question about Kenmore Dryers
Kenmore Elite dryer model 110.85872400 won't start all the time
My dryer has done this to me twice now. I put a load of clothes in push the buttons and nothing happens. Lights up but won't come on. Says ''check Lint screen''. Done that and doesn't help. Came back to it later on in the day and it started right up. What to do if it happens again.
  • 62 Answers
SOURCE: Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Posted on Jan 02, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
  • 15935 Answers
SOURCE: Kenmore elite oasis gas dryer
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
  • 43501 Answers
SOURCE: The air drying the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Posted on Nov 04, 2010
  • 43501 Answers
SOURCE: My kenmore elite dryer - Model 110-82822102 takes
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
Posted on Feb 02, 2011
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Whirlpool made for Sears (Kenmore) HE4 Elite SmartHeat QuietPak9 will not respond to commands, eventually puts 20 on the time screen and the lint light comes on, won't start, won't run, checked...
send the model number,open the door look around the opening where you put the clothes in you should see a tag there.if you unplugged it and it worked then it's not any of the t-stats or door switch most likely a board issue or something to do with the cord from moving it,when you unplug it and plug it back in your resetting the board so this is what it sounds like but can't tell if you even have a board without model number.
Jan 14, 2018 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE5 Electric Dryer, Model 110.8708 The dryer will not rotate when I push the start button, the "sensing revising est. time" lights up amber in the Cycle Status display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 24, 2011 | Dryers
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
