Question about LG L1720P 17" LCD Monitor
Problem with Flatron L1720P monitor
The demo mode for the screen is changing at different times.How do you turn off demo mode to maintain one setting?
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
pgmadhav
  • 145 Answers
SOURCE: powersaving mode
I think your signal Cable is not connected properly.please check. Is your computer booting. Can you see HDD acivity LED blinking in your CPU?
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Posted on Jul 27, 2009
  • 2841 Answers
SOURCE: after starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Posted on Aug 28, 2009
jmgldsmth
  • 1906 Answers
SOURCE: lg flatron w1952tq monitor goes immediatly into power saving mode
reinstall windows
Posted on Sep 06, 2009
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
Jan 04, 2014 | LG Flatron Computers & Internet
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron w1952TQ screen half darker on right side
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Aug 04, 2009 | LG Flatron L1919S LCD Monitor
Hooked up a used 17" LG Flatron L1720P flat Panel. When I turn it on it says Power Saving Analog Mode and goes black, no instructions with it.
Make sure your power cables are connected properly. Sounds like it's not getting any video data from the graphics card.
If it is not your graphics card, It could be a dead monitor.
Feb 09, 2008 | Computers & Internet
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
LG L1720P 17" LCD Monitor Logo
222 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
