Question about SanDisk Sansa Clip MP3 Player
My sansa clip 2gb has only 60 songs on it,but it says that it is already completely full.I've tried erasing everything and reseting it. Even with no songs on it it claims that 1.5 gb have already been used.Help?
  • 54 Answers
What i would recommend you to do is to format the device and transfer all the songs over..There might be a corruption on your device operating system...and format it should solve the problem you are having..
Thank you
Posted on Mar 06, 2009
I have sansa clip 2gb. I reset it completely. When I turn it on again i find the same settings again. Ive tried everything every kind of formatting but its setting wont change nor the data on it could be...
Plug it into your computer via USB, then copy the files over. Make sure you are formatting the memory card, and not the camera's internal memory. As a side note, formatting the card will not reset the settigns, and resetting the settings will not format the memory card
Mar 08, 2011 | Cameras
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
It got hanged..it can be turned and the buttons are not functioning
Tips & Warnings
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
Instructions
Complete Reset
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
My Sansa Clip 2GB MP3 player won't let me add any more songs to it, even though there's 1.26 GB still available. I don't want to reformat the player, cuz that'll delete the songs I already have on there. ...
Hi there..
When you say having difficulty in adding the songs in CLIP, though you have enough space. I'd kindly request you to check for the number of songs that you have added.
Because when you add as MP3 player by default its bit rate is 128kbps so you can add up to 500 songs only. Kindly have a check on it.
I have given the number of songs that can be added with related to size of MP3 player..
Size of the player :512MB 1GB 2GB 4GB 8GB 16GB 32GB
Number of songs : 125 250 500 1000 2000 4000 8000
Kindly revert if any clarifications....
Jan 30, 2010 | SanDisk Sansa Clip MP3 Player
Cant find any song on my sansa clip
The songs could be in the wrong format, but here are some things you can try:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
I have the Sansa Clip MP3 2gb.....I have downloaded about 50 songs with no problems, but now everytime I try to download, it shows a red circle with the slash across it and it will not download. I have...
Sounds like the files you tried to download are in the wrong format.
-Tha Mp3 Doctor
Dec 25, 2008 | SanDisk Sansa Clip MP3 Player
I try to listen to one particular song, but Sansaclip 2gb freezes
Epsilon - delete that one song and see if the other songs play fine
unschool:
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB rarely turns on.
-Tha Mp3 Doctor
Oct 20, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
