My peavey ul 115 bass bin will only work through its bi amp input. Why is this ?. The other one works fine but when I switch speakers I have the same problem. Can you help please ?..Thank you.
  • coffeyg May 11, 2009
    Excellent work Dan. It was the crossover. Found a flaw in one of the solder joints. Well done and thanks.
  • 4,234 Answers
The bi-amp jacks bypass the internal crossover. You need to look at the crossover section and see if an internal protection fuse has blown or if hte crossover itself is smoked.
Posted on Mar 05, 2009
Peavey 115s bass amplifier
Contact Peavey toll free at 877-732-8391 or by email at,
Apr 04, 2014 | Peavey Electronics Peavey Tour Tnt 115...
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Hi,I have 2 sp2 cabs,getting sound thru the horn but none to the speaker,any ideas ? thanks
2 possibilities here:
*Speaker coils got fried or,
*Input jack named "Low" in the Bi-Amp section has a loose contact, as they are switch also.
Hope this helps.
Sep 24, 2012 | Peavey SP2 PA Passive Speaker
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Jul 28, 2012 | Peavey SP2 PA Passive Speaker
Peavey tnt 115 schematics
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Feb 26, 2012 | Peavey Electronics Peavey Tour Tnt 115...
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Feb 12, 2012 | Peavey Music
How do i biamp these speakers they have a biamp plug in the rear do i need a special cable to do this
The two input jacks are parallel connected, to allow you to chain extra speakers together. There is no facility on this model to bypass the crossover and bi-amplify horn and driver separately. Nor should you need to. Just make sure you use a power amp rated for at least 400 watts per channel at 8 ohms.
Sep 23, 2011 | Peavey PV 115 Speaker PA Passive
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
367 people viewed this question
