Question about HP 48gx Calculator
When I turned on my 48gx a month ago some of the alpha keys did not work. Today most of the keys(alpha,numeric as well as functions) don't work. I've owned this unit for over 7 years and have barley used it. Is their a repair manual I can buy? Who repairs 48gx's?. Thanks. Nino
  • rjones421 Apr 07, 2009
    i dropped my calculator and now my function buttons do not work. help!
  • HP Master
  • 7,993 Answers
Before thinking of repairs, you should first determine if it needs repairs.
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Posted on Nov 07, 2009
  • k24674 Nov 08, 2009
    If calculator requires repairs,
    There is an HP customer self repair (CSR) which you can
    contact. On the site it is said that the service is available for
    products under warranty or on contract. but you have nothing to lose by
    contacting them. Here is the link to the web site.
    - You can also try this site. They do repairs on most models, except the newer ones.
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
My HP 48GX recently have ((.)) in the display. I thought that is the indicator of low battery. However, I replace battery new several times the same display still appears. Even after turn off...
Somehow an alarm got set. Execute the command ACK once and see whether the indicator goes away.
To enter the command, press and hold the ALPHA key, then press and release the A, C, and K keys in turn, then release ALPHA, and press ENTER. But you already knew that, didn't you?
Oct 25, 2011 | HP 48gx Calculator
How do you enter fractions into the ti-84 plus?
It depends on the version of the Operating system.
This works for Older and newer OS
Enter numerator, press the [division key], enter the denominator, press the [MATH] key and select [1:ToFrac] [ENTER]
With the newer OS versions 2.53 MP and following you can manipulate fraction more easily. If your calculator MODE is set to MathPrint, you can use the [Alpha][Function keys] to access some functionalities
This gives you access to the Tabs shown in the following screen capture.
Press 1:n/d for improper fractions or 2:Un/d for mixed numbers.
Press [ALPHA][Y=/F1] to activate the FRAC menu. You get a template for a stacked fraction, where you enter the numerator and denominator at their right places. Note that fractions are always reduced to their simplest forms.
Aug 25, 2011 | Texas Instruments TI-84 Plus Calculator
Keys that have Alpha and Numeric always show numeric and not alph
Try replacing the keyboard. sounds like a button is stuck and is causing the problem.
Jun 03, 2010 | IBM ThinkPad T41 Notebook
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
CASIO fx-300ES
  1. To store numerical values in the variables A,B,C,D,X,Y and M you use the [SHIFT][RCL] key combination to access the (STOre) function.
  2. In what follows [ key] is the physical key and (key) is the SHIFTED key
  3. ex: store the value 13 in variable A
  4. 13 [SHIFT][RCL] (STORE) [(-)] (A)
  5. The calculator displays 13 --> A on top line and 13.000.. on bottom line.
  • To recall a value stored in a variable ex: recall value stored in variable A
  • Press [RCL][(-)] (A)
  • Calculator displays A on top line and 13 on bottom line.
If you need to use the variables A,B,C,D,X,Y, and the = sign to create an expression to be solved with the solve( function you must press the [ALPHA] key
=: [ALPHA] [CALC](=)
A: [ALPHA][(-)] (A)
B: [ALPHA][ 0 ' "] (B)
X: [ALPHA][ ) ] (X)
Y:[ALPHA][S<=>D] (Y)
Jan 05, 2010 | Casio fx-300ES Calculator
I have symbol LS2208 handheld, Keyboard Wedge what is the setting to make my handheld recognize "Ctrl + S" ? I have tried this but still not work : *1st trial : Enable Convert to Code 39, Enable Code 39...
If your barcode is $V scan the following barcodes from the LS2208 Product Reference Guide.
Begin New Rule
Specific String At Start
$ (from the Alpha-Numeric section of the guide)
S (from the Alpha-Numeric section of the guide)
End of Message (from the Alpha-Numeric section of the guide)
Send Control S
Save Rule
That should do it.
Jul 09, 2009 | Symbol LS2208 Handheld
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
End of Message
Send F2
Save Rule
That should do it!
May 06, 2009 | Symbol LS2208 Handheld
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
HP 48gx Calculator Logo
175 people viewed this question
Ben Johnson
