Question about ASUS P4SGX-MX Motherboard
In win set up
When i install anew windows i face aproblem after it instalal the boot screen , it said that error load opearting system
  • Joseph Cross May 11, 2010
    What operating system are you installing, what was your previous operating system, and what is the exact error message you receive?
  • 530 Answers
Hi im josh in cebu phils. friend try this stuff to help you solve the problem.
This is a new error message in Windows XP that is displayed after you've had a program crash. (In Windows XP—in most cases—a program crash doesn't crash the entire operating system.) The message goes on to tell you that a log of this error has been created, and then prompts you to "please tell Microsoft about this problem." If you click the Send Error Report button, your computer will connect to the Internet and send the aforementioned error report to Microsoft. You also have the option to not send the report.
What happens when you click the Send Error Report button? Well, you can see for yourself by clicking the "To see what data this error report contains, click here" link. Windows will now display a totally incomprehensible collection of technical information that doesn't tell you diddly squat.
The big concern, of course, is how much of this information is technical and how much is personal; most users don't want to send Microsoft any more personal data than they absolutely have to. Microsoft says that they don't intentionally collect your name, address, email address, or any other personal information—however, the error report itself might include data files that contain this type of information.
So, should you send the error report? I'd recommend not, as you don't directly benefit from it; Microsoft uses this information for future bug fixes, not to help you with your specific problem. Just click the Don't Send button and continue with whatever you were doing before the message appeared.
By the way, if you get this message every time you turn on your PC, you need to update your version of Windows XP with Service Pack 1. This is a bug in the original Windows XP code that affects a small number of systems, and was fixed by Microsoft in SP1.
Unmountable boot volume This message is generated when certain Windows XP files become garbled, making your hard disk inaccessible. The solution is to use XP's new Recovery Console utility to repair the installation. Follow these steps:
  1. Reboot your computer using the Windows installation CD.
  2. When you see the Welcome to Setup screen, press the R key on your keyboard to start the Recovery Console.
  3. You're now presented with a command prompt. Enter chkdsk and press Enter.
  4. Enter exit and press Enter to quit the Recovery Console and restart your computer.
If this doesn't fix the problem, restart the Recovery Console and run the chkdsk /r command.
Windows protection error This error typically occurs when your computer attempts to load or unload a problematic virtual device driver (VXD). In most cases, the problematic driver is mentioned in the error message; in other cases, however, you'll have no clue as to what is causing the problem.
If you can track down the driver causing the problem, you can usually fix things by reinstalling or updating the driver, repairing any damaged Registry entries, or eliminating any driver conflicts.
good luck friend.
Posted on Mar 05, 2009
How to install windows 7 on toshiba satellite c50-a634
On the first screen you see on start up should ask "To enter setup press (ESC or DEL or F1). You need to know which key to depress to enter BIOS setup. Once you enter BIOS (Basic Input Output System you would need to setup your boot priority to your CD or DVD drive. Once you do that you will need to save your configuration and with your operating system disk in the disk drive restart your computer and then you will need to select Boot from CD or DVD, which ever type drive you have and your operating system setup should start.
GOOD LUCK!
Feb 19, 2014 | Computers & Internet
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Blue Screen Error Windows 7 Dual boot config: stop: 0x0000007e (0xFFFFFFFFC0000005, 0XFFFFF80002EE4338, 0xfffff8802fc4838, 0xfffff88002fc4OAD) I have a Hp pavilion dv-7 1020us laptop, getting a blue screen...
If have Bootable windows 7 install it .
Installation guide WIN XP http://www.windowsreinstall.com/articles/bios/ http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx VISTA http://vistaultimate.windowsreinstall.com/repairstartup/repairstartup.htmHope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Computers & Internet
Windows Vista BSOD
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
Win 7 blue screen of death on shutdown? happens on one in five shutdowns the others take several minutes (10) to complete the process.
Then press any key.
Then type "y"
Jul 16, 2010 | Dell Computers & Internet
Need to boot in restore mode. loaded a driver and its know going to the blue screen
Then press any key.
Then type "y"
Mar 13, 2010 | Computers & Internet
Windows is resuming message
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
You can try this first before the XP repair :
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
Nov 04, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Task manager in win xp keeps blinking, it will not closed, no matter what i push nothing, plus win xp keep freezing any solution how to fix this problem
VIrus infection?
to check and secure u need:
win-xp cd or other bootable win-cd, seperate up-to-date antivir software on cd or usb-stick,
your passwords
procedures:
boot system from cd/dvd (do not bother if screen resolution is different from usually),
exit windows-setup,
insert antivir-cd or stick, run full system scan.
found infections? remove/erase these files(antivir will do that for you)
if possible, back-up personal data (my folder, music, save games, etc.)
this data has to virchecked by another protected system before reinstallation !
boot from win-xp cd-rom, run setup until repair options are available,
repair your xp on harddisk(xp-will do that mostly), exit setup without installing win xp anew
boot system from hd, ignore error messages, run vircheck again.
if you're lucky, this will do, else lemmie know
Jun 13, 2009 | Dell Inspiron 6000 Notebook
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
ASUS P4SGX-MX Motherboard Logo
245 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
