Question about Whirlpool Duet GHW9150P Front Load Washer
Baffles in washer
I need to install new baffles in my Whirlpool duet washer. How is this done Thanks Joe
    President:
  • Whirlpool Master
  • 2,651 Answers
The new baffles arefairly easy to install, they go over the hole and then pull foward to lock into place.. the new bsaffle should also come with a screw to "lock" it, in place. in order to securethis screw you need to remove the top cover of the unit,(3 screws across theback) after removing the top youll see a black hose going directly into thetop of the tub prbably an inch or so . gently pull that hose out from thetub. It simply locks itself inplace.. after removing you can spin the inner drum around till thenew baffle is directly under the "hole" where you can now see a small hole inth eunderside of baffle to secure.. just remember to resecure that hose or youll have a flood on your hands
Posted on Mar 04, 2009
How do you replace baffles in whirlpool duet wfw9150?
by removing the top u can get to the baffles which are screwed in on outside of tub
Feb 22, 2015 | Whirlpool WFW9150W Front Load Washer
Baffles broke o my
Can search on Google to buy a new baffles then just slide in the new one to replace the broken part.
Oct 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Drum is so out of balance baffles are being scraped off
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in.  The new ones dont screw from behind.  They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple.  But there not cheap-You can order them through Sears and pay 23.95 each.
Mar 09, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
How to replace whirlpool duet GHW9200LW baffles
easy repair, they simply slide over hte slits in the tib and firmly pull forard to snap/lock into place. there should also be a screw included in the kit, remove the top of washer (3 screws across the back of the lid)after removing hte main top toull see a black accordian like hose leading to the top of the tub assy, from the dispensor box to the left. remove this hose from the tub( pulls out of the hole), then simply turn the tub form the inside till the baffle you installed is at the 12 o'clock positon your screw hole will be right there. RESECURE THE HOSE, reassemble the top and your done!
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replacement baffle installation
thats why we are here,thanks for the compliment
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fins where can i get new ones
These are called drum baffles. They can be found at repairclinic.com. Type in your model number and search for item #1058883. A set of three of them goes for about $34. It is cheaper to buy them in this quantity as a single baffle ranges in price from $22 to $34, depending on which website you go to. The baffles should have installation instructions with them. Of not, let me know. I hope this helps you.
Jul 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal De
