Question about Acer Aspire 5050-3242 Notebook
My acer laptop screen crack and I trid to coonnect it to monitor
It didnt work only in safe mode
  • Anonymous Apr 05, 2009
    mine does the same thing it will only come up the screen in safe mode ?
    Scholar:
  • 93 Answers
You will more than likely need to enable the external monitor port of the laptop, using the Fn key, and one of the F Keys along the top. On the Travelmate's it's usually F5, so hold the Fn Key and press F5, with the monitor connected and powered up. You should find it springs into life. If not, you need to look for the monitor key on your laptop. It will look like an F Key along the top, but will have a little symbol showing two monitors on it (two rounded edge rectangles).
Posted on Mar 05, 2009
Acer monitor wont exit power save mode. Ive tryed 2 different monitors. 1 the acer the other a dell and didnt work on both, but the dell works fine as long as its not that pc. I removed the motherboard...
Assuming that it is an "external" monitor, and not the built-in LCD screen in your notebook, you have to tell your computer which option you want:
* output only to internal screen
* output only to external monitor
* output to both internal & external.
Look for a BLUE-coloured 'FN' key on your keyboard, and a button that cycles through the above 3 settings. Push that button while HOLDING the 'FN' key down.
If your computer is set to "internal-only", then the external monitor will _stay_ in "power-save" mode, although the monitor will work fine if connected to some other "desktop" computer.
Apr 02, 2010 | Acer Aspire One PC Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Attaching external monitor to acer aspire 3682wxmi
I wouldnt put something like that in, sounds like your having a driver issue,
Jan 04, 2009 | Acer Aspire 3680 Laptop
Monitor not working
try going to safe mode,restart pc then press f8 for advance boot menu,go to safe mode,choose administrator,reenable display adapter again..eiether thru device manager or display properties
Jun 25, 2008 | Acer Aspire 3680 Laptop
Laptop problem
can you see the bios screen then follow the following
when you laptop is booting press F 8 then select boot in safe mode then from device driver you can enable the display adapter.
post your findings
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
External monitor
Try going into cmos and enabling multi display (external)
Also u can boot into safe mode and restore windows to a previous day
Next u can save your file on a flash drive then reinstall windows
Hopw this helps ... u also have an s video port
thanks
jaywizz
Nov 18, 2007 | Acer Aspire 5500 5570-2609 Laptop
Booting up
what is happening is that the screen resolution of the notebook is not matching the capabilities of the monitor and is therefore going into power saving mode, unfortunately you wont be able to change it as the screen is damaged, that is why it works in safe mode as the resolution is only 640 x 480 without any graphics drivers
Aug 29, 2007 | HP (D7580-60003) Motherboard
Acer Aspire 5050-3242 Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
