Question about Maytag Atlantis MAV6000 Top Load Washer
When the wash cycle is over, there seems to be a large amount of water still in the washer. Is this normal? When you turn the tub by hand, you can hear the tub moving through water.
  • 4 Answers
COULD BE A BLOCKED FILTER OR TUBE LEADING TO IT IT SHOULD BE AT BOTTOM BEHIND TRIM AT FRONT ITS A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST IT AND PULL IT OUT MAKE SURE NO FLUFF OR ONEY ETC STUC IN IT COULD ALSO BE PIPE AT BACK OF THIS BLOCKED WITH POWDER LAY MACHINE ON ITS BACK ROMOVE CLIP AND CHECK PIPE
Posted on Mar 04, 2009
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in...
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Aug 04, 2010 | Samsung WF203ANW Front Load Washer
Screen flashing "LE" and will not finish spin cycle?
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
May 24, 2010 | LG WM-2277HW Front Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
I just did a load of laundry at my mom's beach house. Second load so far is fine, however, first load seemed to leek from underneath. All water/drainage connections were dry. We moved and cleaned area and...
If all connections were dry, the water may have overflowed the top of the tub during a spin /rinse cycle. That could happen if there was a lot of water (i.e. set for large load) and a small amount of clothes.
Jul 08, 2009 | Washing Machines
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Nov 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dear rxpert. I have washer Maytag Neptune Model MAH5500BWW Model 67787785ZH. After, The washer completed the Work, that still have water inside of washer (I hand to turned the basket inside the washer I...
This is actually normal. It is normal to have water between the wash basket (stainless steel tub) and the outer wash tub (plastic). There shouldn't be a problem unless the water is excessive enough to pool inside the wash tub itself or overflow onto the floor. You will always find a small amount of residual water between the tubs. Don't waste your money on a service call unless you absolutely have to.
Apr 10, 2008 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
