Question about Panasonic CT-36HX40 36" TV
TV will not turn on.
TV was working fine. Then when we turned it off we were unable to turn it on with remote or manually. The screen is completely black as if it is not getting power. However the circuit is fine and all other items plugged into the surge protector are functioning normally. This set was purchased new and was manufactured in July 2002.
    Genius:
  • 1,074 Answers
Have a reairman look at your tv the problem is bigger than what you can imagine technically you are having problem in your power supply which consist of a memory chip, regulator, flyback,and some resitors and caps one or a combination of these went bad.good luck.
Posted on Mar 05, 2009
Lost signal
You have changed channels and now it's on the air. If your box is providing a signal on the 3rd or 4th channel you have to get back to those.
Aug 29, 2017 | Televison & Video
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sharp 70 lc70le847u . When turning tv on unable to change channels and remote will not work. Must turn tv on and off several times for tv to operate. After that digitals channels are non exitant. Must...
It sounds that the main system control memory IC has damaged. Do a reset to this set and check. Refer its user manual to know how to make it a hard reset.
Jan 16, 2013 | Sharp 70" Quattron LED Smart 3D TV -...
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
Mar 16, 2009 | Toshiba REGZA 26HL47 TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV -Ferguson (Wide Screen) model no: W7023U. unable to operate either with remote control or manually.
Is it possible it has locked itself? It can be locked in 3 ways according to manual.
1. by pressing the remote's stand by key for more than 3 secs.
2. By programming an auto stop.
3. By putting it on stand by after programming a wake-up time.
Flashing "red on" indicates it is locked. It can only be turned on by the remote. Press any number key on the remote to unlock it.
Aug 16, 2008 | Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Panasonic CT-36HX40 36" TV Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
