Question about Compaq Armada E500 Notebook
How do i get into bios
What exact keys do i hit to get bios?explain it to me like im a four year old thanks
When the first screen displays, immediately press the F10 key if your computer was built in 2006 or later (came with Vista). Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
Posted on Mar 04, 2009
Cant access bios or boot menu on ga-78lmt-usb3. tried changing keyboard but no luck.
Does the board work? Maybe you tried an unsuccessful BIOS upgrade?
How about explaining exactly what happens when you try hitting F2?
Mar 25, 2014 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
I have hp compaq 6730s before its got xp windows now the windows is corrupted now when I instal xp windows the system doesn't boot with external cd/dvd rom since the its own dvd rom doesn't work properly...
2008 PC from HP(old compaq name)
RECOVERY this PC ,per the book. (Ive done it)
this PC has a working F11 key if the HDD not bad, not changed out or the F11 partitions not damaged,
Power on hit F11 per the service manual. page 141
http://h10032.www1.hp.com/ctg/Manual/c01613452
CD boot fails
to boot to CD you must hit a key, called hit any key
to boot CD (aka. offically El Torito spec, wiki that and learn this)
If you dont hit (I use the huge space bar so easy to reach)
then no CD boots ever. by DESIGN. on new PCs that is true
and now you have to turn off SAFE BOOT too.
so those rules are first.
some PC, even make me hit (HP) the space bar to boot USB sticks this too is a fact. so do that.
my guess F11 is dead so you used discs, unstated disks , no HP disks (RIGHT>?)
XP the dead OS, this means adding things, , to the PC.
will fail. XP plug and play is dead, for vast things now for 3 long years, since MS ended this support. why not upgrade XP
to W7?
Old PCs do not like to boot , to external drives, its modern IDEA that (2008 is not too old,but IDK , if yours has it)
If you did boot to CD , inside or outside
XP (from MS ,not HP) will ask you to find drivers, and tell you to hit F6 and insert a floppy, tell me how you can get past here?
you cant, using NON HP install medial
XP is 2001 disks, 16 years old laying about. from MS
and guess what it cant see your HDD. due to no SATA drivers.
so the path you are on is full of pitfalls. see?
a modern feature in BIOS,its 100% a features of BIOS to boot any USB or External drive, (but eSATA might boot , not you no esata)
you posted with no mention of what external drive you have.
USB , esata, or what? Im guessing USB cable external drives.
the External drive needs a power pack to run right i most cases.
in bios, go to ALL screens, power on hammer F10
Setup bios is F10, go to all screens and turn on all USB features.
then change boot order to.
CD (hit space bar to boot CDs or DVD)
USB (hit space bar to boot USB devices (any key = space bar)
HDD.
then if all that above shows up F9 can be used to override above.
F9 only works if and only if.
1: bios supports it,! (IDK)
2: bios, has all USB features turned on, in other pages in BIOS.
including USB boot , turned on, if seen there. it must be on.
Enabled!
3: F9 only changes boot order this time, it does not enable features, that do not exist. ever.
why in the world not get a good CD/DRIVE. its like $10 used on ebay, pocket change, no?
or install with USB sticks?
there is legacy USB setting in BIOS, turn that on.
I can not teach you BIOS. (ive seen them all, so know this.)
but not yours, HP chances them like the weather, like the changing of the wind, directions. makers of BIOS changed 4 times!
and upgrades on BIOS changed on some HP PC, 10 times. or more. so I know NOTHING here, nor will most others due to that FACT. (unless theirs, is same as yours exactly)
only you can can explore BIOS, page by page and see what is there.
Test 1. (all techs have this in there KIT)
boot from USB stick, NOT external DVD drive)
if this fails doing DVD external boots is not possible.
find say any ISO for Unbuntu 17 linux, and burn the USB stick
using rufus. the boot the stick (fail now)?????????
that is the test for USB boot if that fails the PC is too old
and only fixing your bad DVD drive is the only cure.
Do not run XP with out SP3, once you have it running
XP has 700 exploits, and is a virus magnet.
never use XP is the best answer, but you you are not there yet.
so only BIOS matters now, that and only that NOW>
if the USB test 1 above works, I would.
id buy W7 from microsoft.com
the burn a stick
then load w7 , now it has future.
this PC is supported by HP in W7
here is the proof here
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-6730s-notebook-pc/3687778
never run XP or VISTA today, 2017, they are now officially dead.
Learn that booting is a function of BIOS not windows.
windows is a goal and is only startup files to load windows.
booting happens at the lowest levels ,in BIOS.
BIOS has code in my newer PC to boot to any USB device.
but not external drives.
tricks for compaq old
6730b the CD is called,
'Notebook Upgrade Bay'
(odd name that)
but I have a SDD in mine so not so odd !
trick 2, is some compaq change sata to IDE or the CD will not boot. (sad no?)_
BTW my HP laptop can boot to both bays, HDD and upgrade bay
both bays in mine are SDD. one is w10 other is Ununtu 17.
booting to external drives are the most difficult tasks of all
some do , some dont.
but I always start with a stick first. test that , for booting
then go wild with external drives. (booting )
this is all for now, we can peel the onion as deep as you want, ask.
Nov 25, 2017 | HP Compaq 6730s Notebook
Hard Disc Not Exist
You need to get into the BIOS screen and set the boot order so that the CD drive boots first. Then it will boot to the cd and tell you the same thing. That the hard disk has failed and cannot be found.
Nov 22, 2017 | HP Pavilion dv7-1245dx Notebook
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
Jan 31, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
Computer won't start - multiple symptoms. 1st attempt fan turns on, lites on, nothing boots up. won't turn off, must hold on/off swtch 5 seconds. Then maybe same as before and fan turns off and get a...
Serious issue. Problem could be corrupt CMOS, corrupted OS, bad hard drive, motherboard, or other peripheral.
Try disconnecting everything except memory chips and see what happens. See if unit turns on; if so introduce one of the disconnected items one by one until you come across the situation where it does not work. Then you have identified the culprit.
Aug 06, 2017 | HP Compaq Presario SR1650NX...
Hi, i have a pavilion a1250n Hp pc with window xp and i turned it on today and got stuck on the HP logo Screen, but can (or can't) press any F key's. i tried taking out the hard drive and all usb port ,...
If posts and two beeps it is a memory issue. If it is not posting there may be a corrupt cmos. If not that, you might have a bad hard drive, corrupt OS, bad peripheral. If you have an xp install disk you can attempt a OS repair operation Good luck - you have your work cut out for you.
Sep 07, 2017 | HP Pavilion dv2000t Notebook
Hewlett-packard hp biscotti. the LCD screen keeps flashing a blue and white screen and won't even let me log into windows. I've had this for less that a week and problems were noticed from day one (the...
HP Biscuit. i take mine with butter, LOL
G72259 (missing dash)
NO OS STATED no op system , W7?
i cant ever tell anyone there skill sets, who can?
if you had posted a photo of the mess on that screen we SURE
can answer, accurately,
explaining any screen in words, is mostly a waste
except like , (black screen with these words frozen
the real name is (and old)
G72-259WM
Intel Pentium dual-core
does it run battery out ., and AC line pack plugged in correctly?
i guess its 7 years old?
step 2 does BIOS work
power on, hot keys ESC, F9 F11.
does the BIOS message
"hit ESC key to enter HP setup" does this show up
IT MUST AND IS STEP 2,
getting to windows is next.
step 3 if windows is corruptted
the F11 key reloads or run F11 restore, hit fix starter fills.
step 3, BIOS , go to the service page
run ram test.
then run HDD test.
do they pass
if HDD fails, its bad, a bad drive.
Jul 04, 2017 | HEWLETT-PACKARD HP G72259WM Notebook
Bios access on a tiny
Ok sometimes when I do not know exactly what is the exact key to hit to get to bios setting. You can do this procedure.
After POST quickly hit the button PAUSE or after pressing On button hit PAUSE then ENTER until you seen the list of button to be hit to get into bios setting.
Normally it will flag some Button to be hit like hit ESC = to go to bios setting, F1 = for help and others. if you doesnt catch it up reboot it again.
Hope it helps. Goodluck
May 26, 2009 | Tiny Computers B1996 19" CRT Monitor
Toshiba laptop bios password
check the cmos battery on the board remove it and wait for 15min then put it back and restart the system
May 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Hp 5000 pavilion reset bios password
not exactly, the old pentiums need to have bios reinstalled from dos command screen, or from a disk. not autoinstall like the newer pentiums and above.
check your warranty for FREE here
Feb 22, 2008 | HP Pavilion dv4000 Notebook
Compaq Armada E500 Notebook Logo
171 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
