Question about Nikon D60 Digital Camera
Lcd problem!!! My new d60 has a similar problem, the lcd does work very well indoor but when  i get outside the lcd goes off and on
  • wvijay Apr 15, 2009
    Will try what you say. Shade the sensor .. thanks.
  • pam100red Apr 17, 2009
    Exactly the same happened to my camera today. LCD works inside perfectly, but flickers on MOST settings outside.
    It's not happened before? Camera 6mths old.................?
    I changed the setting, so that the sensor was disabled and LCD stays on permanently...its solved the problem!!......Wonder why its started though?
    Any suggestions?
The problem is the sensor thats right below the viewfinder. The sensor is made to turn the lcd off when you put your eye up to it . The sunlight is activating the sensor try shading it and it will be fine.
Posted on Mar 19, 2009
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
My Optura 300 worked fine for years but now is only filming indoors. The moment I step outside the screen goes white and that is what is filming as well.
Sound like a malfunctioning CCD (Charge Coupled Device) image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check this link for additional details in this previous solutions for an Defective CCD and next contact your Canon service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 04, 2011 | Canon Optura 300 Mini DV Digital Camcorder
New Nikon D60 switching itself off...
Go into the menu and scroll to "reset"...follow the on-screen instructions. If that doesn't work, you need to take the new Nikon back.
Oct 23, 2009 | Nikon D60 Digital Camera
Lens will not auto focus with flash up
Not sure of you camera model, but the flash will fire momentarily when you try to focus indoors as there is not enough light for the auto focus to work. This is so the camera can determine a distance from the subject to the camera. This is called focus assist (ref to your manual). It will work outdoors as there is enough light and contrast for the focus to work.
Kit lenses included with the camera are notoriously known not to focus well in dark conditions.
Oct 11, 2009 | Nikon D60 Digital Camera
I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Jul 26, 2009 | Nikon D60 Digital Camera
Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Jun 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Dust stuck under glass on the lcd screen of my d60
If you purchased your D60 new, you could sent it in to Nikon for cleaning but personally, I'd wait a while if it's not affecting the camera's functions. If you need warranty work within the first year, you can send the camera in for that work, and they'll clean under the LCD while servicing the camera.
May 31, 2009 | Nikon D60 Digital Camera
Nikon D60 Screen failure when SD Card inserted
You can try other SD card , or insert your SD card in other camera to check it out which part have problem first.
Jan 31, 2009 | Nikon D60 Digital Camera
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Nikon D60 Digital Camera Logo
109 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
