Question about Cobra 148 GTL 120-Channels Base CB Radio
148 GTL-B 60 CHANNEL W LOWER SIDE BAND
MY MODULATION GETS CLIPPED EVEN WHEN ON MY TURNER SUPER SIDE KICK.
cAN I MAKE AN ADJUSTMENT ON MODULATION?
  • lakegazer Mar 08, 2009
    Hey thanks man, that was it. What is VR12 right next to it because I accidently moved it a bit...
    My modulation is now about 80%
  • 40 Answers
AFTER LOOKING AT THE SCHEMATIC DRAWING VR 11 IS THE MODULATION ADJUSTER TURN THE DYNAMIC ALL THE WAY CLOCKWISE REMOVE THE SPEAKER COVER AND LOOK TOWARD THE BACK OF TH RADIO YOU WILL SEE A TRANSFORMER WITHE THE FACEPLATE TOWARD YOU ON THE LEFT SIDE YOU SHOULD FIND VR11 TURN THAT POT ONLY DO NOT THINK YOU WILL TUNE THE RADIO YOURSELF BECAUSE IT WILL MESS IT UP AND IT WILL COST ANYWHERE FORM $50 TO 75.00 TO GET IT ALIGNED.TURN VR11 TO OPEN THE MODULATION CIRCUIT YOU WILL KNOW IF YOU GO THE WRONG WAY YOU WILL LOOSE MODULATION TURN IT OPPOSITE AND IT WILL COME BACK MAKE SURE YOU HAVE A ANTENNA CONECTED WHILE YOU KEY THE MIC TO MAKE THIS ADJUSTMENT.
Posted on Mar 06, 2009
Want to lower my dead key on my cobra 148 gtl mobile...where do i find the adjuster?
need to get a watt meter hooked up to then go the where the final is and look aroung for a tuning slug marked L38 and that is the baby you have to turn in order to power down this radio.
Nov 09, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
How to increase the power out put of my 148 gtl-dx cobra to up to 5watts ?
clip diode D11..Turn coil ferrites near finals it will numbered like say: L10,L20,L14 or something etc. It should already factory go like 3 watts to 10 watts on a real out meter. The radio meter is a simulated but not accurate meter read. But crank ferrite coils until meter reaches 5 watts on radio meter..and lock it down there OK.
Apr 18, 2011 | Cobra 29 LTD CB Radio
I have a Cobra 148 mounted on the hump in a pickup truck and it works fine. Then I plugged in a old Turner +3 desk microphone and I get bad feedback when it is keyed up and I can also hear my voice thru...
You're most likely getting lots of RF feedback from the metal cab of your truck,combined with the real sensitive nature of the amplified Turner mike.I would put an old original Cobra (coffin mike) handheld mike or a Astatic Roadking 56 (RK56) on it.They are really hard to beat,especially when you have lots of feedback & squealing. I also have a 148GTL (malaysia made) that has a Turner +3 deskmike & it squeals in my truck but not in the house. The 148GTL has given me better service than ANY other radio I've owned.It has 120 channels (freeband) & upper & lower sideband. I think mine is a 5pin Cobra-type plug-in. Try a simpler mike & good luck. Squirrly
Mar 13, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Schematics for a cobra 148 NW
Most units do NOT allow modulation adjustment as any more than 90-100% modulation causes adjacent channel signal "Splatter" therefore is subject to restrictions, hence generally that is locked. Also there really is no reason to have more than 100% modulation..as well ... why? I would suggest a voice/speech "Compressor" would be more suited.
Jan 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl vr12
if you want more than that you can clip the limiter insde the radio that will be r 131 by the first can with the face of the radio toward you on the right. in front of the can. there is a transistor in front of the can then the resistor.
Mar 09, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl new model
Hello bluzfan, Do you remember the old 40 channel CBs? they used basic A3A transmission (dual sideband single carrier)remember how you got crosstalk sometimes, if your power was too high? Then they went to 80 channel CBs (using a single side band as Lower Side Band (lsb) and the other as the upper side band (usb))? more crosstalk but they invented anl (automatic noise limiter)circuitry to compensate. Now you have the 120 channel CB which uses a form of side band multiplexing (20QAM) to generate 3 times more channel density 40 X 3 = 120. Here is my problem; Cobra should not have done this because you will have massive crosstalk and unaudible sounds because of the increase in channels but not an increase in initial (physical)bandwidth. I hate to tell you this but the only cure for the is to use it in 40 channel or 80 channel mode forget the 120 channel mode, or get a radio with better channel separation.
Oct 07, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
299 people viewed this question
Top Cobra Radio Communications Experts
Iron
Iron
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
