Question about Sharp AR-275 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
Have a Sharp AR-275 copier with fax module. Cannot find the menu option to change the sender ID information that appears at the top of very outgoing fax page (company name / fax #, etc). Not addressed in the Sharp user manual. Anyone know how to access this edit option?
    Sniper:
  • 54 Answers
Push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Posted on Apr 17, 2009
How do i set the ip address on a AR-405
Depending on the interface option set up in your copier, you will either access the printing setup options via the Custom Settings option, then enter the Key Operator access code to view the expanded menu or you can press the 'Copy' button to the left of the LCD screen and look for Main Menu options, then make sure you've enabled TCP/IP (You may have to reset the copier in order to enable it). You should be able to enter the IP address manually.
Sep 18, 2009 | Sharp AR-275 Copier
How do i change the IP address on the sharp ar 275 copier?
press printer button >special key then you can browse through arrow button check there you can see how to change IP address
Jul 19, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Cannot clear stored fax data?
look in the fax manual there should be a section on that
If you have no manual call the company where the fax machine was mad.
May 13, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-275 Copier Logo
215 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
