Question about Air Tools & Compressors
Air leaks between head and cylinder
Craftsman air compressor 12 gallon 1hp oil lubricated model no. 921.166400
Need to know proper torque on head bolts.
    President:
  • 1,922 Answers
Either the head gasket is gone or the rings are shot
Posted on Oct 06, 2009
2 Suggested Answers
compman66
  • 169 Answers
SOURCE: I have 12 gal.1hp craftsman mod.921-166400 won,t
I would have to say if you are blowing oil out the crankcase that you have a piston or rings problem
Posted on Dec 11, 2009
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
Why won't it pump up past 40#?
If you don't have any air leaks, the cylinder head gasket is probably bad on the pump. Easy fix for less than $10. you can get the parts you need here:
http://www.mastertoolrepair.com/sears-craftsman-919195411-p-48270.html or ebay.com. For around $50 you can get the whole rebuild kit.
May 09, 2014 | Craftsman 20 Gallon Portable Horizontal...
What are are the tork spec on the clyinder head bolts
Torque setting for that cylinder head would be around 20 ft/lb and about 30% less if the bolt threads are lubricated before insertion.
Jun 22, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Craftsman 3 gallon 1hp. Motor runs but no pressure buildup. Oil level okay and no obvious leaks.
Your motor is good and your pump is in need of being rebuilt. I would price both the rebuild and the cost of replacement all together as there are many good cheap used compressors crying for a home.
Aug 20, 2009 | Air Tools & Compressors
Have 12 gallon / 1HP Craftsman compressor, accidentally ran it while it was low on oil....about half way low. It shut itself off. Then, I added oil and it started up. But now it builds pressure VERY slowly...
Not the motor, but probably the compressor shot. Heat from friction (due to running without oil) probably scored the cylinder walls, which allows air to escape past the piston and rings, making the compressor VERY inefficient. Some compressors have replaceable cylinders... Not sure if the very small ones do or not.
Jun 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Dec 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
175 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
