Question about OKI B4300 Led Printer
Paper jam upper paper jam...no paper in mechine, cant clear jam message, so printer doesnt work. ?????????????/
  • delicate_mee Apr 01, 2009
    i have the half paper jamed from lower try...what to do now .. please be quick!
  • 6,784 Answers
OK, you will need to preform a hard reset. unplug the unit for 5 min.
Posted on Mar 04, 2009
My dell printer shows error after I have cleared the paper jam.
Try and check the ink or maybe the paper is scrunched up smooth them out.. If this doesnt work then sorry this all i can do XD
Apr 04, 2013 | Dell 1250c Color LED Laser-Class Printer...
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
It says paper jam but there's nothing there i have tried to check the insides but there is no paper jammed just won't work
Sometimes high cotton content paper will deposit paper "dust fibers" in the paper path and roller gears. Or there is a small torn piece of paper in the paper pathway somewhere. I have found bits of paper in the upper roller section on my Lexmark 5470 in the past. If that is not the problem unplug the power supply for a few minutes and then restart it. That should clear the error message.
Mar 06, 2011 | Lexmark X5250 All-In-One InkJet Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Problem with Canon MP600
I had the same problem with my Canon Pixma MP610.
After stripping the printer down I found there is a lever in the path of the paper that operates a photo electric sensor. This can get stuck in the wrong position. To reset it get a sheet of A4 paper or (better) card fold back a 1 cm strip on the top edge of the paper and press it down flat. Open the rear cover and insert the sheet folded edge first and folded flap upper most over the top of the upper set of rubber rollers. Push it into the machine as far as it will go and then withdraw it. You should feel a little resistance or here a click as the lever is reset. You printer should now work.
Several hours of frustartion and foul language have brought you this fix. I hope it works for you.
Regards
Jon
Jan 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon mp600r paper jams every time a second page is printed
Jo48,
You have a faulty sensor in your print mechinism. This could be the print mechinism itself or the sensor. Either way it wil require the unit to be stripped down and repaired by a qualified canon service tech due to the need to re align certian rollers and gears in the unit. Only a canon service tech can do this properly. Sorry dude, but them is the facts.
If the unit is under warranty, canon will repair it for nothing, however if it isn't, you might consider the difference between the cost of the repair and the cost of a replacement unit.
Gremlin11
Dec 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper Jam
Most likely a bad or obstructed sensor. Use compressed air to blow around the top and back of the printer removing heavy paper dust and look under the pickup rollers for small pieces of ripped paper. If the sensor is bad, contact service and support.
Jul 29, 2008 | Canon PIXMA MP460 All-In-One InkJet...
CLEAR PAPER JAM STAYES ON I CANT SEE ANYTHING
Providing the printer brand and model can help zeroing on the problem but paper jam error that won't go away usually mean that the sensor lever got stucked. With the printer unplug, check the paper path. A small piece of paper may have torn and got stuck in the sensor lever. In rare occasion, the sensor itself is damaged or broken off.
fixya!
Apr 06, 2008 | Canon PIXMA MX310 All-In-One Printer
OKI B4300 Led Printer Logo
412 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
