Question about KitchenAid Dishwashers
The flashing light blinks 7 times on the clean indicator area , but the dishwasher will not function and when you press cancel it starts running but nothing washes through any cycle at all. please help
    Sergeant:
    Champion:
  • 338 Answers
Ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a heating element and control board kit that would need to be installed. you can reset the dishwasher by pushing "high temp wash" and "heated dry" back and forth until all the lights light up then you can hit the cancel and drain button twice.. put detergent in and run it.
Posted on Mar 04, 2009
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
DISHWASHER BLINKS 7 TIMES ON CLEAN ONLY RUN ON CANCEL
-high temp wash
-heated dry
-high temp wash
-heated dry
Please rate this solution as Fixya and revret for further assistance.
Thanks
Rylee
Jul 03, 2009 | Kenmore Dishwashers
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
-high temp wash
-heated dry
-high temp wash
-heated dry
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light will not go out
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
296 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
