Question about Brother MFC 7420 All-In-One Laser Printer
Paper feeder is not straight
Paper feeder sends copies crooked, no matter if they are auto feed or manual feed
    Problem Solver:
  • 19 Answers
I found the problem with the image coming out skewed.
When the toner cartridge is replaced it is easy to dislodge one of the springs on the inside .
There is one on the left and one on the right side.
If one comes loose then the paper will feed through crooked.
Posted on Apr 02, 2010
    Genius:
  • 1,198 Answers
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Posted on Apr 27, 2009
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
What causes the copy to be lopsided when using the feeder
I'm not sure what lopsided means??? Are you saying that the image is crooked? If you feed the paper 180 degree then the way you are feeding it now, are they still crooked? Also, do the pages get jammed? Also, look to see if one of the hings are broken? If one is broken, it's a dead give away for your problem. If that is not the problem, I would loosing up the screw that hold the adf on and move the adf a bit till the copies come out straight. Once the copies are coming out straight, tighting the adf hing screws and you are done...... Good Luck
Dec 07, 2012 | Ricoh Aficio 3025P Black and White Copier
Image print on paper slanting
Does it only happen when you copy through the auto feeder or from the contact glass too? If it's just from the feeder, then the rollers in the feeder are slipping and not feeding the paper straight, and need to be cleaned/replaced. If it happens from the contact glass, then it is most likely the rollers that move the paper through the machine that need cleaning - primarily the registration roller, but really all rollers from the paper tray to the exit should probably be serviced, and/or replaced where necessary.
Jun 05, 2009 | Canon NP 6545 Copier
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Document feeder jams
When you put your paper in, check the side clamps are set correct, if there is a gap at one edge, your feeding will be all over the place.
Tuck up the clamps to clamp the paper, not too tight where you bend the paper, but tight enough to hold it correctly.
Regards
Richard
Mar 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Copying problem
check paper through paper cassette, then through bypass,if fault occurs on both, it is possible the registration roller area is possibly faulty.
There are other reasons for this relating to image formation, but please start with paper feed.
Jan 29, 2008 | Sharp AR-207 Copier
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7420 All-In-One Laser Printer Logo
745 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
