Question about Kenmore HE2 Plus Front Load Washer
Kenmore he2 wont fill with water - Kenmore HE2 Plus Front Load Washer
  • darlene_mart Mar 04, 2009
    checked everything ,were stumped ,thanks anyway
  • darlene_mart Mar 05, 2009
    The washer acts like its going to wash a load of clothes,except it wont start filling with water ,Hoses are fine, door locks and unlocks ,valves are good .checked almost every part ,
    Problem Solver:
  • 17 Answers
Open the top cover, disconnect wire harness to pressure switch (located right side of washer) start washer, if washer starts to fill stop washer immediately and replace pressure switch.
Posted on Mar 08, 2009
    President:
  • Kenmore Master
  • 2,651 Answers
First off check your incoming water supply.. also make sure your not using stainless steel hoses manufactured withthe name "flood safe"" big issue with these hoses shutting off premature(they have a built in shut off check valvewithin the hose itself, .. replacethehoses if you have these. if not and you have good incoming water supply, soundslike yo may have a faulty inlet water valve.although usually onyl no hot or no cald the fact you haveno either water temp, thats odd
Posted on Mar 04, 2009
  • Ron Coons
    Ron Coons Mar 05, 2009
    so when you try to "start"your machine, does it appear to start normally?? door unlock -relock. then withexeption of filling water does it rotate the drum???
  • Ron Coons
    if you have an electrical meter, hers what you can do, if you removeth main top (3 screws along back of unit) youll see the waterinlet valve, ifyou set machine for a cold/cold wash, disconnect the wires fron the cold water valve( standing in front of machine lookin inside the cold water is on left) place you electrical probesin hte connectors andstart machine, you should see a voltage reading of 110-120 volts, when the machine calls for water.( within the first min) if you have that voltage present it means you have a bad water valve. if no voltage possible bad machine control board.
  • 1028 Answers
SOURCE: Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Posted on Oct 09, 2008
  • 220 Answers
SOURCE: f21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Posted on Sep 03, 2009
  • 9 Answers
SOURCE: water keeps filling tub and wont stop.
need a water valve
Posted on Dec 07, 2009
  • 12 Answers
SOURCE: i have the kenmore HE2 front loader. when you turn
there is a water inlet on the right side of the detergent filling cup to flush out the dry detergent. take out the fill and it is midway back on the right(little rubber hose) once you locate that take the top panel off and follow the hose, should lead to a silinoid. this is most likely sticking open, or the line is broken and dumping water into the washer cavity instead of in the detergent cup. hope that gets you started in the right direction.
Posted on Jan 28, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore front-loading washer water fill up when not in use
The problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose and repair the problem yourself:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included steps on how to replace any defective parts and parts resources if you need to order anything. If you have any questions, please let me know. I hope this helps you.
Posted on Apr 15, 2010
Testimonial: "It gave me a very good direction, just haven't finished it. As you said it may be helpful, the washer mode# 110.44932201. Thank you very much!"
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Kenmore he2 won't stop filling
sounds like a faulty inlet valve. if its got 2 pipes at rear too fill. turn 1 off and if it still fills the other 1 is faulty and vise versa
Jun 18, 2014 | Kenmore HE2 Plus Front Load Washer
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore front load He2 fills with water in the dispenser cup then spills out from the dispenser cup onto the floor. Can anyone help?
SOLUTION...DON'T BUY THIS PRODUCT. THEY ARE LEMONS.
Kenmore you failed. Claudia Bennett, Boston
claudiabennett80@aol.com
I should have kept the older unsophisticated model ...my basement smells...I did not know I am supposed to be a technician to wash my clothes!!!!!!!!!!!!
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Not filling to wash
The drain hose is very long. Check to make sure it is not pushed too far down into to drain in wall. If so pull it out as to prevent washer for syphoning water.
May 20, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
823 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
