Question about Freezers
I have a Samsung Rl36sbsw fridge freezer and the freezer is frosting up, the frost free function isn't working all of sudden. before I spend £100 on a technician coming out can you give me rough idea as to how much part for this problem might cost.
thanks
SOURCE: Frosty bottom of Leibher Freezer (supposed to be no frost)
I am trying to contact Leibherr; I see that production is located in the United Kingdom. I have found an office located in New York. I’m sure this is not helpful and your freezer is very expensive and I will try to get technical information (if they will allow me access). Sounds as if the defrost timer is not working and that would be the first thing I would look at if I could see the wiring diagram. If it is a common defrost it will be a timer that cycles every 8 hours. If it’s a digital defrost with circuit board I won’t be able to locate it until I get a response from Leibherr. The problem could also be in the defrost element. Here is the link that I have found. Let me know anything or information you have obtain since the beginning of your search that will help me help you get the problem solved, Thank You, Sea Breeze HVAC http://www.euro-parts.ca/English%20files/specials/index.html
Posted on Oct 26, 2007
SOURCE: ice/frost build up inside the freezer
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
Posted on Nov 19, 2008
SOURCE: frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Posted on Nov 29, 2008
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Posted on Jan 02, 2009
SOURCE: frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Posted on Jul 07, 2009
Aug 31, 2015 | Frost Freezers
Mar 03, 2011 | Freezers
May 04, 2010 | Freezers
Jan 31, 2010 | Freezers
Jul 01, 2009 | Freezers
May 12, 2009 | Freezers
May 04, 2009 | Hoover Freezers
Mar 20, 2009 | Kenmore Freezers
Nov 27, 2008 | Freezers
Jul 17, 2008 | Freezers
293 people viewed this question
