Question about Dell Axim X5 Pocket PC
Want to connect to internet through a desktop with my dell axim
I have a dell axim x5, and when its on the docking station, it connects to my computer fine, but I want to connect it to my internet connection, through my desktop
U hav to download da internet server software to pc............. thn u hav to do some settings............
Posted on Mar 05, 2009
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
We have a Dell Axim X5 that we are trying to connect to a PC. Have obtained a USB data/power sync cable, the Dell appears to charge from this cable however, ActiveSync on the source PC doesn't recognise...
I use AS 4.1. I think the Axim will use up to AS 4.5. I had no problems with sync until SP3 came out. Now I must resart the computer with the Axim connected to sync. If the computer goes into suspend it will no longer connect until restarted.
Attempt a restart with it connected.
I have known others with no ability to get the Axim and other devices to be recognized. Unaware of a solution in that case.
Jul 13, 2009 | Dell Axim X5 Pocket PC
Have a dell axim x5 . how do you transfer files from the pc to ax
For exact to the point instructions we need specifics about what you want to do and with what but here goes...
Can't really help with the connect to the internet without more info than you provided. You need a wireless card, access to a wireless system and the drivers for the card. Even then it is not always consistant.
First I'm assuming you know that you need and have installed Activesync on the computer.
To transfer files to the Axim you simply drop them in the mobile my documents folder that is installed on the desktop when sync files is selected in Activesync. If you don't have it, open Activesync and select" options", check the "files" box. A desktop icon will be added.
If you mean install program files... most of the time you install on the desktop and it adds files to the x5 when you sync.
Sometimes you may need to transfer CAB files to the x5. In that case you will drag and drop the file on your x5 in my computer or on the icon on the desktop just like any other file move to another location
If your trying to sync with the wireless card, I am not familier with the method but in order to get the card to work it needs drivers that must be installed from the computer and through Activesync by wired connection first
May 03, 2009 | Dell Axim X5 Pocket PC
I have a dell axim x5 and it connects to my pc and internet fine when its on the docking station. I just need it to connect to my wireless internet connection wirelessly....
The X5 does NOT have wireless built in. You must add a wireless card (compactflash or SD) They tend to be finicky so do a little research for one that works well with the X5 first before buying.
Apr 08, 2009 | Dell Axim X5 Pocket PC
Dell Palm doesn't sync when laptop on docking station
it get start but doesn't show any think on display and onlyn just it shows allign screen
Dec 02, 2008 | Dell Axim X5 Pocket PC
Dell axim x5 1180 truemobile wireless issues
Only WEP is supported------- also download the rom patch for this card off of the Dell site.
Oct 04, 2007 | Dell Axim X5 Pocket PC
AXIM X5
To copy word documents, simply connect your device to your computer, click "Explorer" in ActiveSync, and then transfer the word document from your desktop to your Pocket PC. ActiveSync will do the conversion from Word to Pocket Word for you. As for wireless internet service, you need a wireless Compact Flash card and data service. Sprint is one of the few companies that offers this, and there is also the Pocket Spider from Enfora which can connect on some wireless networks.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Network access while docked...
Yes you have network access. This device runs Pocket PC 2002. It works like all other Pocket PC 2002 devices.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can the Axim connect to a mobile phone thorugh the IR sensor to connect to the Internet. If not what would be the recommended way to connect through a mobile.(
I can connect my Axim X5 to the Internet using my mobile phone via infrared without a problem. You need to create a new dial-up connection using "Generic Infrared" modem in the setup. The number to be dialled is a function of your mobile phone. On my Nokia 6230i the "number" is *99# for creating a GPRS connection. Your mobile phone has to be correctly set up for Internet access and obviously you have to have a data plan.
Dell Axim X5 Pocket PC Logo
397 people viewed this question
Alun Cox
