Question about Sharper Image (tm) Ionic Breeze Desktop GP Air Purifier
Need a replacement ultraviolet bulb G6W sylvania for my ionic
Where can I get one?
You need a G6T5 - Germicidal Tube Lamp - Mini Bi Pin Base bulb. Several online stores sell them.
Posted on Aug 04, 2009
S1730 sharper image ionic breeze GP
So you need another bulb correct
To order replacement lamps directly from The Sharper Image,
call 1-800-344-5555 and order item number SI922.
Lamps are effective for about 12 months of continuous use.
Dec 02, 2007 | Sharper Image Professional Plus Ionic...
I need to replace the bulb for ionic breeze air purifier S1830
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
this bulb is available on ebay for under $11.00. The release tab for the cover is at the bottom of the cover and it comes off pretty easy. Once the cover is off you turn the lamp 1/4 turn (two clicks) and slide it from it's fixture.
Jul 01, 2009 | Sharper Image Professional Plus Ionic...
Where can I buy replacement grid for ionic breeze professional series model S1831?
Item number on ebay is: 220444965077
$10.99 plus around $5 to ship.
Pull up on the tab on the bottom of the front filter and pull up. You then should be looking at the bulb, which you will turn 1/4 turn (2 clicks). You should then be able to pull the bulb out.
Hope this was helpful.
Jun 10, 2009 | Sharper Image Professional Plus Ionic...
I have an Ionic breeze GP from Sharper Image and since they are no longer in business where do I get replacement bulbs/filters at? Thanks
ebay item number:220444965077
$10.99 plus about $5.00 shipping. They have a phone number posted also. The bulb is easy to replace. Reply to this post if you require instructions.
Feb 17, 2009 | Sharper Image Ionic Breeze GP (SI730) Air...
I need a replacement light bulb for my Ionic breeze?
you can buy the lightbulb on line.. here is the link.. http://www.lightbulbmarket.com/product/738517
It is a Philips ULTRAVIOLET TUV15W/G 15 T8
Nov 26, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Who repairs the sharper image ionic breeze GP
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
Nov 21, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
790 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
