Question about GoVideo Go Video VR3840 DVD Recorder/VCR
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but reports an error when I try to finalize the disc. Any suggestions? Also, I haven't been able to locate any customer support for GoVideo. I assume they're no longer in business. Thanks.
  • jonkalan Mar 07, 2009
    Thanks for your quick and targeted feedback. I tried your ideas, but it didn't work. The machine won't read the disc when I tried to finalize it again. It keeps spitting it out with an error message (bad disc). I think it may be a problem with the machine since this has occurred with different VHS tapes and different brands of DVD-R discs.
    The machine plays VHS tapes and DVDs fine, just won't record the DVDs.
  • 8,596 Answers
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Posted on Mar 05, 2009
Is it possible to copy video from a vhs to a dvd?
If the DVD drive is a recorder, yes. If it is a player only, no. If the tape is copy-protected, recording to a DVD recorder is not possible. Assuming the tapes are not copy-protected, and you are using a DVD recorder with the correct format DVDs (DVD-R for example), you shouldn't have any problems transferring old VHS tapes to DVD.
Jul 05, 2011 | GoVideo DVR4000 DVD Player/VCR
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Cannot record copy protected message
Hello billwade1216,
I'm sorry to inform you but we are unable to disclose those types of details as it is Illegal, and against Fixya's policy.
Sorry for any misunderstandings, thank you for trying Fixya!
Apr 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
Mar 11, 2009 | Toshiba D-VR4 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvdro5
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e this is as close as I have found. Different brand names but basically the same. If you are copying home movies use the av outputs from the vcr to the av inputs of the vcr, then the av outputs of the ILO to the tv - while recording from your tapes. I read somewhere if it is macrovision protected you can bypass it by using the coax out from your vcr to the Antenna in on the ILO and then pick up that signal in your TUNER of the ILO. I have had good success with both, I prefer the av if I can get that to work, better picture, but sometimes it won't record that way, esp old tapes, so try the ant in (coax) if the av doesn't work. Use + R discs or +RW discs (sony brand is the best +R but it doesn't matter on the +RW's)
Oct 25, 2008 | iLO DVDR05 DVD Recorder
Recording from vhs to dvd
As long as you've got the DVD recorder set to the correct "channel" I can't see why it won't work. Why don't you just try it out on a DVD-RW first ? Use RCA cables from the VCR "OUT",  to the DVD recorders "IN" sockets and you'll be okay. If for some unknown reason it doesn't copy you haven't used a good disc. Probably won't copy anything with Macrovision(or other copy protection) though.
Sep 05, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Recording a dvd to the hard drive
look for an option in the DVD menu for dubbing this means to copy contents to hdd (usually cannot do it with copy protected discs but will be ok with a disc you made yourself)
Aug 30, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
169 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
