Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
I am trying to connectmy basement computer to my upstairs office
Downstairs computer is asking for some tcp/ip address?? and the internet light on my router is flashing. is that how it is suppose to be? any feed back would be appreciated,
  • 2 more comments
  • dayalsa Mar 04, 2009
    dear geekman, thanks for responding. i am trying to connect with a cable from my wireless router to the downstairs compute. i been using the wireless router with a card like u mentioned but the problem i have is that the downstairs computer is on the other end of my basement therefore the signal is very week and some times unavailable. i am now trying to connect the basement computer with a cable to the router upstairs. is the internet light on the router suppose to flash? thanks.
  • dayalsa Mar 05, 2009
    thanks mr geekman for taking the time out for me. i will try all over again tomorrow. thanks again.
  • sshorterm Apr 08, 2009
    M
    One Pc is upstairs with modem n cable. I would like to connect to the internet on my PC in the basement. What devices do I need and how do I do it
  • My reply is May 11, 2010
    Are you connecting by cable or Wireless?
  • 201 Answers
Do you have another computer connected to the router, and does it work? Also, have you checked Device Manager on the basement computer to make sure Windows sees the NIC card, and not just the Wireless network card?
Posted on Mar 05, 2009
  • Dell Master
  • 32,281 Answers
Your wireless router issues IP address to your computers.
Your wireless card on your downstairs computer needs to be configured to communicate with the router, ie WEP or WAP encryption - if your have enabled it, SSID etc.
To configure the TCP/IP settings on your downstairs computer -
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Posted on Mar 04, 2009
  • Chris Hingee
    Chris Hingee Mar 04, 2009
    I'M ASSUMING YOU ARE USING A WIRELESS CONNECTION.
  • Chris Hingee
    Chris Hingee Mar 05, 2009
    There are several lights on routers and they vary between manufacturers, so I don't know if there is an Internet connection LED.
    Does your wireless router have a WAN port that is connected to a cable modem or DSL modem or is it a single unit wireless router with an integrated cable/DSL modem?
    I assume your wireless router has several 10baseT ports (these are usually numbered) and if you are running a cable from the router (say it is connected to port 2) to the computer in the basement. The LED port 2 on the router would be lit and if there is any traffic/communication from the computer this LED would flash.
    Also there are usually two LEDs on the network card on the downstairs computer, one is the Link LED which indicates that it is connected to the router (if you don't get a lit LED then the cable is broken, the LED on the router will also be unlit) and the other is the traffic/data LED which flashes when data is transmitted or received from the computer.
    Setting up the TCP/IP settings on the network card is exactly as the same I described for the wireless card except you select the network card/connection instead of the wireless card.
    Hope this solves your problem,
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My second computer downstairs can not make a connection to the internet via my wireless router that is connected to my first computer upstairs
to difficult for explain that your problem. Wireless Router must be set into DHCP mode enabled. And your 1st laptop and 2nd computer have to been set into "Obtain an IP address automatically".
Don't forget to set your Wireless Router in section DNS server, IP range for wireless connectivity, and IP address from your adsl link.
If you confuse, you must call by phone, IT expert for do this...
Sep 07, 2009 | NetGear DG834G Router
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
Can't find internet.
check the ip address on the wireless network connection icon,make sure that the ip address,make sure it is dhcp enable and is within the same range with the router ip.you may also change the channel on your router because the problem is may be with wireless interference,you may be using other wireless devices that are running within the same frequency as your router.(cordless phone,baby monitor talk,microwave ovens,even thick walls and large aquariums)
Sep 11, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Connection keeps going on and off
check the ip addresses with the pc downstairs and see if all the pc's have the same default gateway. If not check your network card or network cable.
May 24, 2008 | Linksys Wireless-G WRT54G Router
Netgear WG111 usb 2.0 adapter lossing connection
you need to set your ip addresses on your computer this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4 this only applies to netgear routers
Oct 18, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
552 people viewed this question
Alun Cox
