Question about Kohler 1014-H2-96 Portrait 5' Whirlpool Bath Tub Finish: Biscuit
My kohler whirlpool wont stay on. It turns off about 1 second after i turn it on
I've had the same problem with my K 1496, which has the same installation instructions as your 1014. I called Kohler and got a very nice tech support woman, who said the usual cause of this problem is that the GFCI breaker has to be wired in a nonstandard way. The installation instructions on p.9 show how to do this (the wire that normally goes to GFCI neutral goes to the ground bus instead), and they'll send you the instructions as a pdf file.
Posted on Oct 24, 2009
    Sergeant:
  • 149 Answers
You have a bad capacitor its located on the top of the electric pump motor. Be sure to turn off the power before attempting to replace it.
Posted on Mar 05, 2009
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Need to find proper carb needle valve settings for case 444 Kohler
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
Wirlpool bath pump doesn't stay on.
If this is a new unit you need to complain to whoever you bought it from. somehow it doesnt surprise me with the kohler name on it. I used to work for a company that sold mostly kohler stuff.
Apr 02, 2010 | Home
Kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
When we press the "on" switch in or Kohler whirlpool tub it trips the wall switch. I changed the wall plug and it still trips when trying to turn it on. It has always worked fine. Any suggestions..
Remove the GFCI WALL OUTLET and try connecting those wires together blk/blk..wht 2 wht...ground to ground and then see if tub will stay on, if not suggest put back together and call qulified whirl pool tech to find short in pump motor.
Please rate. Thank you. jj505
Mar 28, 2009 | Kohler Synchrony K-1192-LH-0 White 5 Feet...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Kohler 1014-H2-96 Portrait 5' Whirlpool Bath Tub Finish: Biscuit Logo
470 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
