Question about Bernina 1008
My Bernina 1530 stitches are faulty - with loops underneath, even though it looks ok on top. When I remove and rethread the bobbin, the stitches are ok for 6-12 inches then start looping again. I tried to clean everything - like the Feed-dog, the bobbin area and the tension plates, changed needles. The problem still happens. This machine is about 7 years old and has not been used much at all, but has not caused any problems before.
  • Anonymous Mar 07, 2009
    Bernina Matic 910
    Stitchs are fine ontop but loops at the bottom
    Novelist:
  • 97 Answers
This is almost always indicative of an upper tension problem.
First, make sure you're using a good quality thread. If you're using thread that's not of European manufacture, you're probably filling your tension assemblies with little fuzzies. Coats and Clark Dual Duty is the most notorious thread for causing tension issues. If you have a bunch of this thread: throw it away or use it for hand sewing.
Turn your machine off, and use some canned air to blow out your upper tension assembly. (It looks like a couple of little cymbals inside the thread path.) Set your tension dial to 4.5.
When threading, right before you actually thread the needle itself, and with the presser foot up, "floss" the thread back and forth by holding the thread at the top by the spool with your right hand, and down by the needle with your left hand. This will ensure that you force the thread into the tension assembly.
Also ensure that your bobbin is oriented the right direction, but this would be a less common cause for your symptom.
If none of these fixes work, you probably need to have your tensions professionally calibrated.
-R
Posted on Mar 09, 2009
Have you taken the bobbin case out and checked that tiny screw. Maybe it loosened up. This is a delicate task but you could try to tighten it just a hair. I have a Bernina 1530 in which the 'board' just went bad and I cannot get the tracking ball to go up or down just sideways. Let me know what you come up with.
Posted on Mar 17, 2009
Tension setting model lx2763how to set the tension top stitch looks good bottom stitch is loose
top tension is incorrect
pull the top thread out and there should be resistance to pulling it before you thread the needle
Nov 11, 2017 | Sewing Machines
My Bernina Artista 185 has been looping the top thread on the underneath side. Is this a tension problem? No amount of adjustment seems to correct it. What can I do to correct the looping problem?
It is a tension problem. My advice is always to double check in the manual that you are threading correctly. With loops underneath, your tension is too loose, or the bobbin is not seated properly.
Nov 18, 2015 | Bernina Sewing Machines
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
Why won't my Bernina zig zag bobbin thread catch underneath; the top looks great.
have you tried changing the needle?
have you tried adjusting the top tension?
May 13, 2012 | Bernina Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
Model #5050: the top stitch looks fine but underneath, massive loops. I've changed the needle, rethreaded the bobbin, altered the thread tension, but still the problem remains. Any ideas? Margaret W.
You may have threaded the machine with the presser foot down. This closes the tension control and the thread cannot properly enter during the threading process.
Re-thread with the presser foot up.
Test the stitching.
Feb 06, 2010 | Singer 5050 Mechanical Sewing Machine
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Monofilament thread nesting up underneath
Mono thread can develop a memory and curl itself around things. I hate the stuff.
Mar 10, 2009 | Bernina Activa 130
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Sewing Machines Logo
694 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
