TCL L40FHDM12 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 8ms, Logo
Posted on Apr 02, 2013
Turning on tcl tv
Remote is broken where is the on off button
m afzal
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Dec 03, 2013
m afzal
Contributor
Level 1:
New Friend:
Answers
8
Questions
Helped
11783
Points
11
There wil be touch buttons on the side . press standby button.tv wil b on
Need the codes for my TCL tv
Universal remote codes can vary depending on the brand and model of the remote control you are using. TCL TVs are often compatible with various universal remotes, and you can typically find the codes in the remote's manual or on the manufacturer's website. However, if you don't have access to the manual, you can try the following steps to find the code:
1. **Automatic Code Search:**
- Turn on your TCL TV.
- Point the universal remote at the TV.
- Press and hold the "Code Search" or "Setup" button on the remote until the LED light turns on.
- Press the "TV" (or another applicable) button on the remote.
- The LED light should blink once and then stay solid.
- Press the "Power" button repeatedly until the TV turns off.
- Once the TV turns off, press the "Enter" or "OK" button on the remote to save the code.
2. **Manual Code Entry:**
- Find the code list that came with your universal remote or check the manufacturer's website for a list of codes.
- Enter the first code for TCL TVs from the list using the number buttons on the remote.
- If the LED light blinks, check if the TV responds to the remote (try turning it off and on).
- If the TV does not respond, repeat the process with the next code until you find the correct one.
3. **Manufacturer's Support:**
- Visit the website of the universal remote's manufacturer and check if they provide code lists or support for TCL TVs.
- You may find an online tool or database to help you find the correct code for your TCL TV model.
Remember that not all universal remotes are compatible with all TV models, so it may take some trial and error to find the correct code. If none of the codes work, you may need to contact the manufacturer of your universal remote for further assistance.
TCL tv keeps going to setup mode every time it is turned on. Had the tv for 2 years and it has only just started doing it
If your TCL TV is continuously going into setup mode every time it is turned on, it can be frustrating. Here are a few troubleshooting steps you can try to resolve the issue:
1. Power Cycle: Turn off the TV and unplug it from the power source. Wait for about 1-2 minutes, then plug it back in and turn it on. This simple power cycle can sometimes help reset the TV's settings and resolve minor glitches.
2. Factory Reset: Perform a factory reset on your TCL TV. Keep in mind that this will erase all customized settings and return the TV to its original factory settings. To do this, navigate to the TV's settings menu (if possible) and look for an option to perform a factory reset. Refer to the user manual for specific instructions on how to access the settings menu and perform the reset.
3. Check Remote Control: Ensure that there are no stuck buttons or issues with the remote control. Sometimes, a stuck button can cause the TV to enter setup mode. Remove the batteries from the remote control and try turning on the TV using the buttons on the TV itself. If the issue resolves, you may need to replace or repair the remote control.
4. Software Update: Check if there are any available software updates for your TCL TV. Visit the TCL support website and search for your TV model to see if there are any firmware updates available. Updating the TV's software can help fix bugs and improve overall performance.
5. Contact TCL Support: If none of the above steps resolve the issue, it's recommended to contact TCL customer support for further assistance. They can provide you with specific troubleshooting steps for your TV model or advise on potential hardware issues that may require professional repair.
When contacting customer support, provide them with the model number, a detailed description of the issue, and any troubleshooting steps you have already attempted. This information will help them assist you more effectively.
7answers
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
2answers
I need service mode for TCL 21F5 model.... Pls help..
To enter service mode on a TCL 21F5 model TV, you will need to follow these steps:
  1. Turn off the TV using the remote control or the power button on the TV.
  2. Press and hold the "Menu" button on the TV.
  3. While holding the "Menu" button, press the power button to turn on the TV.
  4. Release the "Menu" button when the service menu appears on the screen.
Please note that making changes to the service menu can cause permanent damage to your TV if done incorrectly. It is recommended that you only make changes to the service menu if you are familiar with the settings and have proper knowledge of the TV's inner workings.
Also, It's better to check the manual or contact the TCL customer service for more details.
2answers
TCL 21K77 Problem with TV/AV without Remote Control
You may have to find a direct replacement for the remote, no real solution.... Let me know the brand....
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
14helpful
4answers
My TCL 2027U's child lock in on and I can't unlock it
kapag naCHILD LOCKED tapos hindi na maopen ang TV,,,pero nakastandby sya...sira na din ang remote....
anu pwedeng gawin???
please answer...
THANKS
25helpful
2answers
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
