Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
Stopped working Whirlpool side by side Model ED22DQXAB11 Lights are on that's it. What should I change in the control area. Can the PC board go bad?
  • 4wheelin4eve Mar 05, 2009
    I just wanted to know if I needed to change the defrost timer or the PC board that is in the control area
  • 3 Answers
If you open, the lights are always on. It's not a problem, if that's it. But if almost closed and lights are still closed, I have no idea...
Posted on Mar 05, 2009
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light in refrig not working & blue indicator lights out also. Pulled switch & lights still out if I jump the leads. Is there a reset botton.
your motherboard in the lower rear area of the unit is bad,if you have recently replaced burned out lights in the refrige when these lights burn out it causes a surge on this control board and burns the circuit trace,hint:if you hear a rapid clicking noise in this area of the motherboard its a relay trying to latch,a bad board wont let it latch and the lights will dimly flash in the refrige compartment and the digital read-out may be out too
Jan 24, 2010 | Whirlpool GS6SHEXNL Side by Side...
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Compressor stopped. Lights work.
replace the control board in the lower left rearr inside the unit on the left wall
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Check your thermostat assembly.
That is the off/on and temp control in the control panel.
It controls power to the entire machine except the door lights.
Mar 04, 2009 | Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
