Question about Refrigerators
Whirlpool side by side Model ED22DQXAB11 Lights are on that's it. What should I change in the control area. Can the PC board go bad?
  • Refrigerators Master
  • 3,361 Answers
Check your thermostat assembly.
That is the off/on and temp control in the control panel.
It controls power to the entire machine except the door lights.
Posted on Mar 04, 2009
My Whirlpool side-by-side refrigerator/freezer (Model # ED5PHAXSQ00) has power and lights but will not cool or freeze.
Replace the main control board located on the left rear mid side.you can get the board from a local appliances parts store. They will need the model and sereal numbers
May 15, 2016 | Whirlpool Refrigerators
I have model gx5fhdxvq the tempratur in frezzing area fronm -16to -24 i cnt change more
hi.cant understand your problem .going to assume u mean u cant change the temperature or choose.sounds like control panel pcb board faulty.good luck Ali
Jun 27, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool Duet Washer won't turn on. I switched the cords going into the outlet and the dryer works fine on both sides. Thanks.
Do you have any lights on the consel at all? If not you have either a bad user interface (which is the control pannel with the lights) or your have a bad central control unit( Control board).
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore 10658026800 does not cool... where is the defrost timer?
I found the parts page but Kenmore does not have the parts listed. You refrigerator was made by Whirlpool and Sears changed the model number. Looking a the sears photos your model does not have a defrost timer but does have an Adaptive Defrost Control located inside the fresh food compartment and behind the control panel where you set temperatures. Defrost failures and compressors stopping as you said in your post are common for the ADC I will continue to try to cross it over to the Whirlpool Model but most likely that is the problem. When an ADC fails strange things begin to happen. Once you start to look for the ADC unplug and remove the top shelf to help lower the control panel. I will return soon to leave you more contact information and what the part looks like. OK your model came with three different styles of defrost controls located in same area. Timer and two different ADC boards. I will need you to look and read the numbers off of what you find. If a timer we can test, defrost boards usually have burn marks on front or back when damaged. Let me know what you find and we go to next step. Is ice building in freezer rear wall or is just lights on? Sea Breeze
May 09, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light in refrig not working & blue indicator lights out also. Pulled switch & lights still out if I jump the leads. Is there a reset botton.
your motherboard in the lower rear area of the unit is bad,if you have recently replaced burned out lights in the refrige when these lights burn out it causes a surge on this control board and burns the circuit trace,hint:if you hear a rapid clicking noise in this area of the motherboard its a relay trying to latch,a bad board wont let it latch and the lights will dimly flash in the refrige compartment and the digital read-out may be out too
Jan 24, 2010 | Whirlpool GS6SHEXNL Side by Side...
Inside lights not working on frig side, working on freezer side, changed all 3 bulubs
You have a bad control board , located behind the refrig , mounted to the bottom left corner , inside the white plastic box . Also , the temp adjustment light , should be out . This board , is held onto the refrig , by those 2 , 1/4 " screws . It is easily replaceable , and costs about $80.00 .
Dec 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I HAVE A WHIRLPOOL GC1SHAXMB00 SIDE/SIDE CANNOT CHANGE FRIDGE TEM
try the control bd first this is a bad problem with this model
Oct 11, 2009 | Refrigerators
Stopped working
If you open, the lights are always on. It's not a problem, if that's it. But if almost closed and lights are still closed, I have no idea...
Mar 04, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
