Question about HP Photosmart C5180 All-In-One InkJet Printer
The yellow cartridge is out of ink.
II do not have another one. I need to print. Why can't I just print in BLACK?
    Scholar:
  • 135 Answers
You probably can.
Before you print, go into print options and select "Black ink only".
Let me know if it works. It should do as it's a standard option on almost every printer.
Posted on Mar 04, 2009
Prints yellow instead of black
I had the same problem with my Brother MFC 490 CW. It suddenly started printing yellow instead of black. I believe my problem was cause by a mislabeled third party black ink cartridge. The cartridge was labelled black but it had a yellow end piece. In any case I took out the black cartridge and replaced with another. Initially it made no difference I assume because some yellow ink was still in the tube. After 10 or so pages of printing the print turned darker. I also did three cleanings and unplugged the unit and then plugged it back in. I am not sure what if anything these latter two actions accomplished, but I wanted to report all I did in case they were actually part of the solution. My own conclusion is that it was simply a mislabeled cartridge.
Dec 05, 2011 | Brother MFC-290C Multifunction Color...
Pro905 is out of color ink. can i print in black and white text only
The Lexmark Platinum Pro905 needs all four inks to have substantial ink for printing at all times in order to prevent damage to the printhead. This is why a user has to replace empty ink cartridges to continue printing. This includes color cartridges for black only jobs.
Nov 26, 2011 | Lexmark Platinum Pro905 multifunction...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
