Question about Canon PIXMA iP90 Mobile Printer
IP90 The following ink tank is not installed Color ink tank.
I have had this problem several times, the color ink tank is installed, have cleaned it. Tried to purge the jets but color ink tank not installed message does not allow. Tried to go to grey scale black ink tank only but error message Color ink tank not installed.
Problem seems to come and go, can any one assist?
5 Suggested Answers
SOURCE: Canon ink tank problems
Totally pissed.  I have the same problem.  **** Canon.
Posted on Apr 13, 2008
SOURCE: CanonPIXMA iP90 Color Ink Tank installation problem
can anyone tell me what to do
Posted on Sep 24, 2008
yboyandrei
  • 828 Answers
SOURCE: Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Posted on Aug 15, 2009
Testimonial: "Fix worked perfectly and quick response, thanks."
cene765
  • 787 Answers
SOURCE: i need to reset my ip90 waste ink tank
Look here.
Posted on Nov 05, 2009
pineworks
  • 4041 Answers
SOURCE: I have purchased a
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
IP90- peformed all of the cleaning procedures
It may need a new printhead, QY6-0052-000, but there is also a firmware upgrade the shop has to do to help black cleaning.
Nov 25, 2009 | Canon PIXMA iP90 Mobile Printer
Printing nice but very light
the ink may have become very old. i would suggest you to make a refill again.
Jul 30, 2008 | Canon PIXMA iP90 InkJet Printer
In tank not installed
Are you using genuine Canon inks? Try remove inks, power off, power on, let start up without ink, power off, installed inks
Jan 14, 2008 | Canon PIXMA iP90 InkJet Printer
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
My canon iP90 portable printer stopped recognizing the installation of the color ink tank. It keeps asking to install the color ink cartridge and won't print until the color ink cartridge is recognized
According to Canon, the if several actions did not correct the issue, it was a hardware problem. They sent me the location of the closest repair shop. I spoke to them and to do the repair is $80 + parts which my research estimated at between $50-$80, for a total cost of $130-$160 plus 10% cook county Illinois sales tax. I have ordered a new updated printer for a total of $215 plus no tax or shipping charge. I'll be taking the old printer to a location for recycling. I can't believe how disposable this equipment has become. What a waste of raw materials and energy.
Jun 03, 2009 | Canon PIXMA iP90 Mobile Printer
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 WONT PRINT BLACK
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
433 people viewed this question
old marine
old marine
