Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Control locked the panel says that the contols are locked.
  • Anonymous Mar 15, 2009
    control panel is lit up & locked, unable to wash clothes now..first time ever happened.
    President:
  • Whirlpool Master
  • 2,651 Answers
Look forthe button marked "control lock" and hold it for 3 secs to unlock it
Posted on Mar 04, 2009
The control lock light on. Control panel not working. How do I get the contol lock suspended?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool GHW9400 Front Load Washer
I have a whirlpool duet and the contol panel locked light on
My dear friend this is an very common problem people do face with. Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Sep 30, 2010 | Whirlpool Washing Machines
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Contol locked came on.
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
MY DRYER IS STUCK ON CONTOL LOCK HOW DO I GET IT OFF
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as a shorted keypad on the operator console). If you need further assistance, please let me know. I hope this corrects the problem for you.
Mar 03, 2010 | Dryers
Control locked stays on
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature of the washer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are also included in the owner's manual.
If these steps do not provide you with a solution, you may have a more serious problem than a simple operator intervention. Please let me know if you require additional assistance. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Contol panel not working
do all your buttons work on the panel? if not, replace the user interface, if they do, replace the main control.
Jun 25, 2009 | Maytag 24 in. MDB7751AWS Stainless Steel...
Can't unlock the control panel
Usually in sequence... Program-Mode-Temp Down... Or temp Up to lock
May 24, 2009 | Coleman (5040B750) Patio Heater
Control locked led indicator is on ,there no contol at all
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
May 13, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
