Question about Logitech QuickCam Connect Webcam
Video and Audio not working at same time
My video and audio are never working together. One is always faster than the other. Is there a way to solve this?
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Mar 20, 2009
The audio and movie are not together. The audio is ahead of the movie.
your watching a divx file or h.264 video, or a torrent file, the frame rate is faster than the audio bitrate...whoever gave you that file encoded it wrong. should be mp4 video file. ">
Jan 23, 2014 | Televison & Video
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
HAVE THE DVG-1080P CAMERA, THE AUDIO AND VIDEO DO NOT MATCH UP!. IVE TRIED USING IT IN SEVERAL QUALITY SETTININGS AND ALWAYS END UP WITH AUDIO THAT RUNS FASTER THAN THE VIDEO!
Are you playing the video from the memory card? What I've found is that sometimes the file isn't processed cleanly from the card, than if you'd drag and dropped the video file to your desktop...
Jun 08, 2010 | Polaroid DVG-1080P HD Camcorder
Pioneer avh-p4100 plays my DIVX really slow
Its a media-snafu...DIVX isn't always readable my mobile electronic manufacturer equipment.
sorry :o(
Jun 15, 2009 | Car Audio & Video
I cannot get audio and video together.
Go to Tools | Options | Audio Settings and Video Settings which is how the audio and microphone settings are adjusted in Skype.
It sounds like you might have two microphones or devices with microphones. Make sure the microphone with the webcam you are using, is selected.
Dec 20, 2008 | Logitech Quickcam Chat Webcam
Audio and video problems using nero 7
go here and download video and audio codec here http://www.free-codecs.com/k_lite_Mega_Codec_Pack_download.htm
trust me it will solve your problem....
only 1 person rate me after all.. lol.. i give up if i got no more rate after this
Mar 23, 2008 | Microsoft Office Outlook 2003 for PC
Audio/video synchronization problem
I have tried several versions of Pinnacle products over the years, and have had serious problems with ALL of them. Constant crashes, re-boots, glitches, dropped frames, etc. Sound lagging behind the picture is one of many problems, and can be avoided only be capturing short clips and editing them together. A real pain. i finally gave up on Pinnacle and bought Sony Vegas Movie Studio Platinum. It has a longer learing curve than Pinnacle, but in the long run it has more features and is very stable. Sony Vegas also works with Vista. Pinnacle 10 does NOT, depsite what Pinnacle and the salespeople tell you.
Mar 17, 2008 | Pinnacle Dazzle Video Creator Platinum...
Sound lags picture
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
4) Convert audio to wav with CDex
5) Open original video in VirtualDub, choose "direct stream copy" for video and "Wav audio" with "Full audio processing" with cbr mp3 compression (and interleaving with appropriate delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
Feb 12, 2007 | Philips DivX DVD Player
Logitech QuickCam Connect Webcam Logo
89 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
