I reviewed the list of common error codes and c 65 didn't pop up. Samsung says that you need to schedule servicing on the fridge via their support center (on their website). Thank you.
Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
