Question about Canon imageRUNNER 5000 Copier
Canon IR5000 not running 20 lb. will run 60lb. and cover. 20 gets stuck in middle
    Scholar:
  • 136 Answers
If it's getting stuck in the Middle , I am assuming it's getting stuck right a the fusing section, Ok if it is running 60 lbs of paper greatly but, jams in the Middle , this tells me your fuser needs to be adjusted, This is something you don't want to do if your NOT a Service Technician most likely if your fuser was adjusted for 60lb paper the temperture was also adjusted so the paper won't be too too hot, I am certain your fusing unit will need to be adjusted or the Upper fuser/Lower Fusers are worn. Yea, you'll have to call a indiepent or an authorized dealer for this, unless you know how to rebuild the fuser yourself- be careful- this is exteremely hot unit.
Posted on Mar 05, 2009
Canon ip90 will not take paper through the printer
I have had similar problems with Canon and Epson printers. Standard solutions are not earth shaking, but worth a try. Use paper heavier than 20 lb, get a roller cleaner paper from the manufacturer
and run it through to clean the rollers.
Jun 04, 2014 | Canon PIXMA iP90 Mobile Printer
How to reinstall canon IR5000
I have canon IR5000 machine. The data on the HD is corupted how do I reinstall the system software
Jan 24, 2011 | Canon iR5000-6000-L1 PS Ver 1.0
Sir i have IR5000 and every 2nd or 3rd copy is getting stuck in nails inside the machine what should i do..? please help me
you have to replace separation claws or you can take off one of the nails the copy stuck on it
Nov 21, 2010 | Canon imageRUNNER 5000 Copier
Jam 0205 in ir5000 canon machine. Please give me
there could be a small piece of paper stuck wehre the vertical path sensor is. it is showing a stationary jam at the vertical path 3 paper sensor. there is more than likely a sensor that has become wedged or has a piece of paper holding the sensor closed instead of open in or around drawer #3
Jun 11, 2010 | Canon imageRUNNER 5000 Copier
.85/lb of nuts and .55/lb of nuts to equal 60lb @.75/lb
Convert what you know into a couple of equations. You'll need two equations because there are two unknowns. Call them X = pounds of nuts that sell for .85/lb and Y = pounds of nuts selling for .55/lb.
Equation a): X+Y=60 (total weight sold is 60 lbs)
Equation b): .85X+.55Y=45.00 (because we want to sell 60 lbs at .75/lb)
Rearrange a) to X=60-Y (subtract Y from both sides)
Plug this into equation b) and solve it for Y:
.85X+.55Y=45.00
.85(60-Y)+.55Y=45.00
51.00 - .85Y + .55Y = 45.00
51.00 - .30Y = 45.00
6.00 = .30Y
Y = 6.00/.30 = 20 lbs
From equation a) then, X = 40 lbs. Check the results by solving equation b).
.85x40 + .55x20 = 34.00 + 11.00 = 45.00 (checks!)
(If either of those nuts is pistachios, where do I send my money? That's a good price and I want some!)
Mar 19, 2010 | SoftMath Algebrator - Algebra Homework...
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Copies fade out after 18 pages. Toner is not low. when copying in group, copies 16 etc get progressively lighter in middle of documents
This problem isn't a typical wear problem, but saying that I'd first replace the charge coronas and clean the grid really well. Also replace the transfer coronas and maybe pretransfer coronas too. It sounds like the High voltage system in your ir5000 is being overburdened so it's best to go after the most obvious problems first. I've also seen this sort of thing happen with things that get stuck in the transfer and seperation corona areas, so look for arcing or debris down there as well. Good luck
Dec 22, 2009 | Canon imageRUNNER 5000 Copier
How to clean my canon ir5000 and how to keep it save from dust.
if paper jam before fixing check fixing gears, if paper jam in the middle of copier then check sepration carona and drum finger.
Jun 14, 2009 | Canon imageRUNNER 5000 Copier
Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
71 people viewed this question
old marine
old marine
