Question about Canon P200-DHIII Calculator
I am trying to set time and date on a calculator
I have a canon P200DH III Calculator that has a time and date function. I cannot fogure out how to set them -- I have tried holding down the time set (=) button but it only flashes and I can't change the numbers -- same thing with the date I can't figure how to change it
  • Anonymous Mar 24, 2014
    Trying to set date and time on my p200dh III can you help
  • 3 Answers
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Posted on Apr 21, 2009
  • Cheri Murphy Apr 21, 2009
    Maybe the battery inside is going out also.
What you can do is set the calendar or time on the screen push button the = until the time or calendar numbers start flashing then set the correct time with the numbers from the calculator also to change the format of the calendar push the % button, to set the time on 12/24 push the division sign and the X to set AM/PM.
Posted on Apr 27, 2009
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
I don't have the manual for my canon p23-dhv calculator. How so you set the date?
Hold down the time set key (M+ key) for 3 seconds. Then hit the date/time key. Enter in the correct date. Hit the time set key again to set. To set the time hit the date/time key twice to bring up the time.
Hope this helps.
Oct 30, 2009 | Canon P23-DHV Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Setting the date and time
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Jan 08, 2009 | Canon P23-DHIII Calculator
Can't set date
Download the user manual (P23-DH III) from here:
Nov 15, 2008 | Canon P23-DH Calculator
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Canon P200-DHIII Calculator Logo
551 people viewed this question
old marine
old marine
