Question about Plumbing
How do I take apart a moen 8710 single handle kitchen faucet. There isn't a set screw I think the top might pop off but I'm not sure.
    Sniper:
  • 58 Answers
The top pops off and there is a crew under it. It's all pretty easy but when you put it back together you have to do a tricky angle kick with the handle. Watch carefully as you take the handle off and put it on and off several times to see what is needed. If you do it wrong the handle sets on top of the black thing and doesn't work right, The cartridge in the faucet pulls out with difficulty if you have hard water. There is a little clip near the the top that holds the cartridge in. You should be able to get a repair kit that has the cartridge and new O-rings for the spout.
Posted on Jun 09, 2009
How to tighten swivel spout of moen kitchen faucet
pop the cover off the top of the spout tighten the screw underneath and replace the cap.
May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
Moen kitchen faucet
Hi Steve-If the faucet is definitely getting water (making sure all the cut-off valves are open along the way), the Moen single handle faucets all use a replaceable cartridge that is available at home supply stores. This cartridge is what regulates the pressure and the temperature of the water coming out of your faucet. This is likely faulty. You'll need to close the supply valves (hot and cold) underneath your sink prior to replacing.
Apr 01, 2014 | Plumbing
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
If you need further assistance please let us know.
Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Is it an allen key to tighten the big single handle in the kitchen? What size?
no,it is a phillip's screw i do believe.pop the top cap and there it is.
Mar 09, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Cant shut water off on coldwater side on single leaver fauctt
is there a logo on the top of the handle,if so pry it off and there is a screw there,on some there may be a hex head screw on the back of the handle out of direct sight for looks
Feb 28, 2010 | Moen Monticello Single-Handle Kitchen...
I need to replace the #14699 retainer pivot nut on my single lever faucet and need to know how to do so.
pop the cap on top the handle,remove screw,work handle off and unscrew retainer nut. a tip,raise the center of cartridge up when you reassemble,so it work's good .
Feb 22, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 87135c - cant take apart
On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Trying to get the handle off a single handle moen kitchen faucet
Hi adelinette,
Pry the cover off the top of the faucet with a little screwdriver. Under the cover you will find an allen head screw. Sometimes a little upward pressure with a screwdriver will help. Unscrew it and start disassemblying. Pay attention to part location as you take the faucet apart. you will be replacing a stem and not a washer when you get into it.
Good Luck and please rate this response, Phil
Jan 03, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Plumbing Logo
1,226 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
