Question about Hoshizaki F-1001M Flake Ice Maker
E4 keeps comeing up on desplay and keeps knoking off
    Scholar:
  • 165 Answers
Read this information properly to know why the error code is popping up on the icemaker of your brand and model  --------------------------------- 1. A High Temperature alert (E1 code) occurs if the box temperature has exceeded 18°F above the set point for more than two hours. 2. A Low Temperature alert (E2 code) occurs if the box temperature drops 5°F below the set point for more than one hour. These codes will automatically reset when the temperature returns to the set point. 3. Finally, a High Pressure alert (E4 code) occurs if the high pressure control cycles 5 times within one hour. After the high pressure problem has been corrected, the high pressure alert must be manually reset by turning the power off and back on. Hoshizaki reach-ins also include a cleanable condenser air filter. A clean filter light on the control panel illuminates when the filter needs cleaning This light circuit is operated by a bi-metal thermostat located on the compressor discharge line. If the condenser air flow is restricted, the compressor discharge temperature will increase. At 220°F, the thermostat will operate a holding relay to turn the light on. Depressing a momentary push button resets the light circuit after the filter has been cleaned.
Posted on Mar 04, 2009
  • 583 Answers
Unplug it for 1 hour and replug it again to reset the device and solve this problem
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
I just received my pressure cooker and it keeps giving me an error message E4. why?
Generally, the E4 error code means that the sensor in the pc is faulty and needs to be replaced. Contact the place where you bought it immediately (if it's still under warranty) or contact the manufacturer to ask for a replacement.
Good Luck!
Nov 01, 2014 | Home
Motor knoking when oil light comes on
Check the oil pressure with a mechanical gauge, I think you have a low oil pressure
Mar 30, 2013 | 1999 Mercury Sable
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Knoking sound wile driveing it comes and goes
is it more from the front or back of the car ?? over bumps ?? while acelerating or braking ??
on the top of the front struts there's a rubber bushing called the "upper strut mount" this is a commonly replaced item. Also the sway bar bushings are frequently replaced. or, it could be something totally different..... gremlins ??
Dec 24, 2009 | 1999 Volkswagen Cabrio
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Hoshizaki F-1001M Flake Ice Maker Logo
128 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
