Question about Radio Flyer 1800 Big Red Classic Wagon :Unitsize 05001664
The tires are flat
The tires have lost air and I want to reinflate. Problem is when I try to inflate with a compressor or bicycle pump (doesn't screw on to valve) the valve stem pushes back into the tire. Any suggetions?
    Scholar:
  • 135 Answers
You need to purchase an adapter which pushes onto the valve (so it doesn't depress the valve stem) and the other end is a standard screw fix to a bicycle pump.
Any good bicycle store stocks them.
The valve you are desrcibing is pretty standard on racing type bicycles.
Good luck and let me know how you get on.
Posted on Mar 04, 2009
Fix flat tire
You probably have a Presta valve. Go to a bike shop and get an adapter (for about a buck and a half) it screws on that valve and then you have a regular valve to inflate
Aug 30, 2013 | Diamondback Sorrento 26" Mountain Bike
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Nov 01, 2012 | Mini Tools & Hardware - Others
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
How sohuld I take care from my bikes tires?
It is important to get your tires checked from time to time. Second only to wear and tear resulting from dirt,the biggest problem cyclist encounter is with tires. Many inexperienced cyclists tend to ignore the tires. This can lead to dangerous issues. Bicycles tubes are made from a porpus type of rubber called buytl rubber, which allows air to slowly seep out. If tires are not regularly re-inflated to proper volume, they will be to soft. Apart from being much harder to pedal with, soft tires also lead to rim, tube and bicycle wheel damage.Soft tires wear out much faster, and can pop unexpectedly,leaving you stranded. To ensure that tires are propely inflated, pump up road bike tires before every ride, and check mountain bike tires every week. Use an effective pump, ideally ,a bicycle pump with a build in gauge, and observe your bicylce manufaturers information about recommended tire pressure.
Dec 21, 2010 | Cycling
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
Will not take air -- how do you work this pump on this Presta Valve System?
http://en.wikipedia.org/wiki/Presta_valve
"The air pressure in an inflated tire holds the inner valve body shut. A small screw and captive nut on the top of the valve body permits the valve to be screwed shut and ensure that it remains tightly closed. The nut must be unscrewed to permit airflow in either direction (this must be done before attaching a pump). The screw remains captive on the valve body even when unscrewed fully; it is tightened again after the tire is inflated and the pump removed."
May 17, 2010 | Schwinn 174 Men's and Women's 17" Coronado...
How do you inflate a Bicycle tire with the small portable pump? the air is coming from the needle to inflate balls and not from the nozzle. It is a Schwinn small portable bicycle pump.
Usually, the needle used to inflate balls is an attachment to the pump. Is there a lever near the fitting the needle comes out of? Moving the lever 90 degrees from its current position should allow you to pull the needle attachment out. The hole the needle came out of is where the valve stem from your tire goes to pump the tire up. Jam the stem in the hole, crank the lever back to lock it in and pump away. Unlock the lever to release the stem when the tire's inflated and you're golden.
Jul 06, 2009 | Schwinn Cycling
Radio Flyer 1800 Big Red Classic Wagon :Unitsize 05001664 Logo
558 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
