My screen is black,and the power button light keeps flashing.
Just called JVC customer service about this issue and solved it. Step 1 unplug tv for 10 sec and then plug it back in. Step 2 Next hold down the menu and volume - buttons on the side of the TV. Step 3 Turn on the power count 3 seconds let go of the menu and volume- buttons. Worked for the LT-42EM59 model. I hope this helps.
Posted on Apr 26, 2009
Does not work for a Digital Lifestyles television, but thanks!
Posted on Feb 16, 2010
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Power button goes on and off, and no response
Power drain the computer by removing the battery and power adapter and press the power button for 1 minute. then insert back in the battery also the adapter to your computer and start the computer.
If the solution won't work
, try using flash light on the monitor,if you can see anything on your screen, possible backlight is the problem, however to isolate also the issue you may use an external monitor to check if you can have a video using other monitor and if not? you may contact the tech support of your system for possible mechanical failure.
hope it helps.
please post positive comments and rate.
May 13, 2010 | Acer Aspire 5520-5908 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
Jan 19, 2010 | Acer Aspire 4315 Notebook
Power led on hp monitor flashing
mham2525, Did it have a "perfect" picture on it yesterday? You do know that if the COLD-CATHODE-FLUORESCENT-TUBES that are hung on the rear of the LCD PANEL fail to light, all you get is a BLACK screen to look at!!!!! OMG, What shall I do now???? It sure would be nice if all we needed to do was remove the cover and then screw-in 4 new CFL light bulbs into our monitors. YOUR UNIT WILL NEED TO BE TROUBLESHOOTED AND REPAIRED. MOST LIKELY A SMPS/INVERTER BOARD FAILURE. CALL HP TO SEE IF THEY HAVE A SWAPOUT PROGRAM. Bye for now. lmistyrel @aol.com
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Nothing happens only power button lights or turns off
Count the number of flashes for the red power button. I'm not a Hitachi owner, but you can track one down here on fixya and they''ll give you more info. One of the internal components have failed and is keeping the power supply unit from firing up. Do you hear a relay click when you try to turn it on? If so, how many times does it try to fire up?
May 23, 2009 | Hitachi 57F500 57" Rear Projection...
A drop image on screen
hi i have panasonic NV DS 65 initially when i power on the cam it started then after 5 to 10 sec the power light automatically flashes and the buttons on camera doesnt work any more. but now the problem has got worsend the powen light keeps on flashing and no buttons work moreover a drop image is flashed on the screen.
plz have me solve my problem
sam_rav
Jan 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Televison & Video Logo
506 people viewed this question
Top Televison & Video Experts
Electro Med Services...
